You could "surface" mill it with a ball end mill if you don't want to change the design? If you did it that way you could put a radius in the corners? Is this an a arm?
Forget about it. Just give your brother a handsaw, a file and sandpaper.
He will make it by lunch time.
Yes, this is an Arm for an HPI Savage.
I have been reading the posts, so the posts are helpful.
-Jason
I would model radii into the round bosses then use a ball end mill to surface them. This will make them stronger. I can help you with the model and or program. I am on proe/ proman everyday.
