Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > PTC Pro/Manufacture
PTC Pro/Manufacture Discuss PTC Pro/Manufacture software here.
Old 03-20-2007, 02:03 PM
buccilli15's Avatar
buccilli15 is on a distinguished road
"Fixing" surfaces
I'm a new user....When I receive customer data, that was created in a different program, there are numerous "bad-surfaces". What is the easiest way to fix these in Wildfire?
Old 03-21-2007, 12:29 PM
wcssrobb is on a distinguished road
On the imported feature choose :
Edit defination-Geometry-Heal Geometry. A new menu will come up allowing you to zip gaps. On the selector in the botom right set it to quilts and then zip gaps. Remember to solidify all quilts will need to be merged.
Old 03-21-2007, 01:39 PM
buccilli15's Avatar
Thanks!
"low end" HF Spindle or "high end" router for about $1000? biomed_eng DIY-CNC Router Table Machines 14 01-06-2012 01:15 AM
"Fixing" bent engine valve? mmmjboner Bending, Forging,Extrusion... 18 07-16-2007 04:40 PM
Has anyone looked at the "JET" or "Shop Fox" manual machines? boosted General Metal Working Machines 12 03-04-2007 10:33 PM
Vertical system "jerks" and "bangs"?? REVCAM_Bob Servo Motors and Drives 5 06-12-2006 10:09 AM
Add "View New Posts" to "Main Menu" Mr.Chips Forum Questions or Problems 4 04-21-2004 11:54 PM
