Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > PTC Pro/Manufacture
PTC Pro/Manufacture Discuss PTC Pro/Manufacture software here.
Old 03-19-2007, 12:02 AM
skmetal7 is on a distinguished road
Making a hole on an angle
I want to model this part in pro/e but i can't figure out how to make a hole on a certian angle. this is how far i got in modeling it. this part is what makes the plate "wobble" and is pressed onto a bearing. you can see it in these photos.
ID:	33824   Click image for larger version
ID:	33825   Click image for larger version
Old 03-19-2007, 05:00 PM
jjclear is on a distinguished road
First create a datum axis on the "front" plane and offset from the "right" plane. You will use that axis as your pivot point. Next create a datum plane through the axis and at an angle to the "front" plane. Now use that datum as your sketch plane to create the hole.
J. Clear
WTB 3-way angle vise bherr Shopmaster/Shoptask 0 05-31-2006 04:34 PM
G68 angle rotation wevz Daewoo/Doosan 2 09-11-2005 06:54 AM
Right Angle Mount SPEEDRE DIY-CNC Router Table Machines 0 07-26-2005 07:06 PM
Alum Angle Ursine DIY-CNC Router Table Machines 9 05-13-2005 07:49 AM
angle cuts coolman General Metalwork Discussion 1 01-23-2005 12:33 AM
