Got my wildfire 3.0 to work now on my machine. Also got vericut to work with Xp, anyone know how to use vericut, I don't see any NC menus within Pro/e, but I can start vericut outside of Pro....
I'm an experienced pro/e user (8000+hours) and am now getting an upgrade to wildfire. Is there a process for going from pro/e solid model to g-code smoothly and efficiently?
With pro/e, I can export to several formats, step, STL or iges...What are the next steps to easily generate g-code and see the toolpaths etc?
Also are there other modules (or plugins) neccessary in pro/e that I would need? I've seen people refer to pro/manufacturing which i haven't really used much.
u can use vericut in pro manufacturing
yea I found it under opening a new part, open a "manufacturing part'. I thought the manu tab would have been within part level...
Could you shoot over some simple steps for me to get started on a sample part with vericut?
Ive never used the manufacturing or NC machining portions of Pro...
Vericut is just for verifing the toolpath you make. The toolpath them self you make in the manufacturing mode. Its a steep learning curve, but if you have access to coach it shouldnt be that difficult since you already know pro/e
i have tutorial of it. i can send u if u need.tell me how can i send u.
Hi my name is George and I'm a student.I try to find ProNc Post processor for Fanuc 6M or 6M-B.Could you help me with some advices?Where can I find it?And it is reliable to program my self this post processor?Thank you
i m also struggling with this interfacin thing..
want to detail u regardin the same.
using pro/E ver 3.0
able to achieve toolpath gen. not able to generate G codes
thanks.
rahul
caarva@gmail.com
G codes comes from postprocessing the toolpath file with a postprocesser for your given machine. If you just want standard g code you can make a postprocesser yourself in g-post or send me a pm with your email, ive made one to go with mach3
thanks man for your reply.
actually that tool path gen file has got some trouble.i am not able to generate that.hey u can be of great help. if u dont mind i would like to interact through
e-mail..can u please mail me at
caarva@gmail.com or pls give ur e-mail.
thanks a lot.
awating reply
Rahul
hello herco my name is fsa can u send me that tutorial about nc i realy need it cozz i am new learner in pro-nc my email- reves_eng@yahoo.com
thanks
asif fsa
