| PTC Pro/Manufacture Discuss PTC Pro/Manufacture software here. |
| Hmm, think i got it, made my own post processer in g-post, only problem i have is that it outputs N#, where # is linenumber in front of every line and ends every line with $ and when doing repeatedly circles or arcs it doesnt repeat the I and J parameters, anybody knows which setting that controls this or if mach3 can be set to handle this? |
| Hi I'm also very interested in a post for ProE. I use it alot for 3D modelling but I use Edgecam as Cam software. I have made a mach post for Edgecam but have noe experience in the Cam part of ProE. But it would be very interesting to try ProE as a cam software. |
| I think i pretty much have made pp for mach3, just used standard settings and changed some different things like modal settings, block end etc. ProE is awsome for creating toolpath, but its a bit tricky to learn. If somebody wants the pp, just send me a pm |
| hi Guldberg, if you go to the mfg seting then pprocessor, open your one then look at the start/end of program you should un-check the "EOB char at end of each block type image", your dollar sign woes should be solved. enjoy |
| I'm trying to use pro n/c for mach3 as well. I get great mill code, everything works like a charm. I modified a post that was in there to get the correct settings. Lathe toolpaths however are driving me crazy. I cannot get it to output a toolchange or a tool offset. It leaves off lines sometimes. I can get it to work, one sequence at a time, but I cannot seem to get usable code when I need to use more than one tool. More often than not the lathe code will run, but the backplotter will have an unknown error and I can see when the machine moves, but the toolpaths are not displayed. I also cannot figure out how to make it pp code in diameter. I don't like running it in radius. I really want to get it working on the lathe as it works so good for the mill. I love the expert machinist. |
