Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > PTC Pro/Manufacture
PTC Pro/Manufacture Discuss PTC Pro/Manufacture software here.
Old 05-08-2006, 07:14 PM
camtd is on a distinguished road
4 axis indexing
Hi
How is a 4 axis index program done. I understand setting the machine for four axis in the operation setup.
But where do I go from there?
Thank You
Old 05-12-2006, 08:20 AM
paul_r is on a distinguished road
If you're just doing indexing then the easiest thing to do is make all your nc sequences as 3 axis with a different sequence CSYS for each index position. I'd keep it simple by using CSYS all at the same origin as the operation CSYS, just pivoted on your A (or B) axis. If you're doing 4 axis holemaking, the easiest way is to use a 5 axis holemaking routine - the only other option is separate 3 axis holemaking sequences for each orientation.
