Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > PTC Pro/Manufacture
PTC Pro/Manufacture Discuss PTC Pro/Manufacture software here.
Old 09-09-2003, 12:25 PM
mace's Avatar
mace is on a distinguished road
Material removel
Here is an example of material removal feature
the transparent green is the stock
reference part is white inside stock i have material removels for all seq. in op010
mace
Old 09-10-2003, 02:53 PM
pronc is on a distinguished road
Mace,
i could be wrong but it looks like it's a expert machinist part right?
Old 09-10-2003, 03:57 PM
mace's Avatar
It could be made in expert Machinst But i preferr Pro nc
pro nc is faster for me
It is a Nasa Part
Old 09-10-2003, 04:09 PM
Really? are all the wall are vertical? if so i'm very sure i can do it faster in EM than i do it in pro/nc. but tha's just me.
Old 09-10-2003, 04:14 PM
mace's Avatar
Yes all vertical but You must understand I have Mudf files that eilimainate programming of this part took 1.5 hrs to model then 2 hours to program post verify It was a make 2 pc. job done and shipped all in less than a day
mace
Old 09-10-2003, 04:31 PM
less than a day? you guys pretty quick. still i tend to think Em template is quick than udf since it usually takes a few click to redifine a feature in udf. EM template is almost drag and drop. plus stock removal is automatic and more accurate than pro/nc.but i have to confess i only use udf a few times.
Pocket Milling - Less Material Natchamp Visual Mill 5 09-12-2005 09:21 AM
Radius material setup MikeA Mastercam 2 04-25-2005 10:46 AM
Help with warping material snaggletto General Metalwork Discussion 11 04-08-2005 11:22 PM
how to mill 7075 T6 sheet material gcamlibel General Metal Working Machines 11 09-08-2004 02:06 PM
Volume mace PTC Pro/Manufacture 33 10-21-2003 12:44 AM
