We recently purchased a Haas VF-2 that will not run on the same post as our older Haas machines. It does not like redundant moves or having a X or Y move within a G02/G03 line that also has an I,J move. The machine will get "Alarm 982- zero angle move" with our current post.
I do not see a way to eliminate the xy moves in circular motions anywhere in the NC Post Processor. I can manually edit the post to remove all x,y moves in any line that contains an I,J move and the machine runs fine. If anyone knows a way to edit this in the advanced section or something I should check or uncheck it would be greatly appreciated. We are running Wildfire 2.0
