Hey everyone! I'm new to ProE and I'm not in the position of aquiring any tutorials. I have to work things on my own. So, any help would be great from some guys who have been working with ProE for a long time. Here are some things I could really use some hints:
How do you mirror pieces so you don't have to take everything from the beginning?
How can you set the feed and rapid traverse colors?Can you measure on a ramped surface how much the mill will go down, do it doesn't hit your vice or clamp?
Can you describe more than one trajectory in a sketch when using the CUstom Trajectory NC Sequence?
Thanks!
