Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > PTC Pro/Manufacture
PTC Pro/Manufacture Discuss PTC Pro/Manufacture software here.
Old 06-25-2003, 10:55 PM
Xeno is on a distinguished road
holes
When in the standard hole making mode (drilling), I can not control the starting and ending depths. On rare occasions it will take a starting surface and ending surface but normally no matter what surfaces I referance or z inputs I use, when I exit the hole making menu it tells me I haven't entered any depths. I believe this is a bug.
The software will swallow the "automatic" option so I then have to manually adjust the G code (G81, G83 etc).
I'm curious if I'm missing something or if it's a well known bug.
thanks
Tony
xeno@xenomechanics.com
http://www.xenomechanics.com
Old 09-05-2003, 07:11 PM
mace's Avatar
mace is on a distinguished road
Xeno
It sounds to me like you are having graphic interface problem !
1. Do you see the surface highlite after selection ?
2. Do you actually select surface, the surface may just be in query select you must right click to the surface you want when it is highlite then left click! left is you enter right is your query
query=( toggle through surfaces that are in range of graphic pick)
3.You Must have 3 button mouse for Pro E.
4.Pick deep hole for G83 cycle(must enter peck value in Parameter tree) . Pick break chip for G73 Your post Must be set up correctly in order for this to work.
5.Possible non compatable Vidio card
6. Has bugs go I have not had A bug in Pro E since I learned in Complete 99% of the time it is operator error
Please PM me and I can get you up and going fast I have training Material I can Send you
Mace
Holes in stainless flat stock OCNC General Metalwork Discussion 6 06-02-2005 01:03 PM
How to cut holes in Autocad Sanghera SheetCam 5 05-28-2005 01:32 PM
Wanted price to rout some holes Grue Australia, New Zealand Club house 0 07-14-2004 08:41 PM
compound angled holes on 3-axis machine krustykrab General Metal Working Machines 0 05-17-2004 12:49 PM
Working the holes in your molds HuFlungDung OneCNC 0 04-10-2003 09:52 PM
