Are you using surfaces or solids?
Ok now when I go to sweep, cut it doesn't cut anything... its like another surface.
Shaun
my x2 conversion ------> http://www.cnczone.com/forums/showthread.php?t=36403
<insert witty comment here>
derekj308
i copied it 180 degrees and i can see that it cut the solid, but not the surface.
and can i rotate the copy around the z axis so i can have the wave do 1hz instead of 2hz?
Shaun
You've just about got it. I think your cylinder is probably a surface but you can make it a solid and the sweep should cut the groove in it.
derekj308
From your picture I think to achieve 1 cycle you would rotate 180 about your x axis. Are you looking for a full sine wave i.e. + amplitude and - amplitude?
derekj308
ok i got the frequency to change by changing the equation's 180* to 90*
Shaun
Picture please. The post #12 is wrong. I said mirror when I should have said rotate, sorry.
Hide your first revolve and the groove may be shown if the first revolve is a surface and the protrusion is solid.
derekj308
so far...
Shaun
GO IT WOOOHOOOOOOOOOOO!!!!!
Shaun
I reckon hide that first revolve and the original sweep will appear.
derekj308
ok so one side is a little weird lookin ill post a pic
Shaun
Picture please.
derekj308
