creo 4 axis postprocesor for haas
Results 1 to 2 of 2
Thread: creo 4 axis postprocesor for haas
    Jul 2013
    Default creo 4 axis postprocesor for haas
    Registered dharmic's Avatar
    May 2015
    Default Re: creo 4 axis postprocesor for haas
    If you're in the manufacturing mode (ie you're in a manufacturing/NC file), you can go via the Applications panel on the ribbon to "Post Processors" (I think, don't have it open at the moment). It'll open a java application which allows you to clone and modify your current Haas post definition to give it 4th axis capabilities.
    It takes a while but it's there if you can't get one off the shelf.
