Need Help! post processor - simple question
Results 1 to 5 of 5
Thread: post processor - simple question
    May 2012
    Greece
    Default post processor - simple question
    hellooo!!
    i am trying to create a post processor using the pro/manufacture for a 5axis milling machine.
    the machine has 2 rotary axis, B(-5/+110) and C(-360/+360).
    in the option file generator, in tab ''secondary rotary table'' there is a choice for ''nutator angle'' (where, If the secondary rotary axis rotates in an inclined plane (nutator), specify the positive angle of this plane measured from X to Z or Y to Z in a counter clockwise direction)
    the secondary rotery axis for my case is B (rotation about y axis).
    i think the nutator angle for my machine is 0.
    Am i right???
    i am trying to understand what is the ''nutator angle''!!
    please help me!!!
    Oct 2013
    hi,
    i hope that you already found the answer but i will post anyway
    the nutator angle is the angle that live head tool can make it, you will find this info also in gpost help instructions
    Jun 2006
    PAKISTAN
    Nutator angle only applies to the non-orthogonal head. to understand this concept in a better way see the head mechanism of DMU60P.
    I am sure this will work you 100%, otherwise let me know.
    Oct 2013
    hi Shoail,
    I've tried to respond you but it seems that you have exceeded stored private messages
    so I can naot send you pm.
    Best regard.
    Jun 2014
    Default Re: post processor - simple question
    nutator angle is only for headaxis like this
    Nutating CA/CB head Setup
    At this machine nutator angle is 45 deg.The offsets of DZ and DX are needed.
    At orthogonal spindles which centers of C axis and B axis or any other are coincidence nutator angle does not exist and can be ignored.
    Attached Thumbnails Attached Thumbnails post processor - simple question-nutator-angle-jpg
