Page 1 of 3 123 LastLast
Results 1 to 12 of 36
Thread: new rotary table for its special industrial function
    Banned
    Sep 2009
    china
    Dear my friends, I , Cindy, am very glad to introduce our new rotary table for you. As you see, in the picture I enclosed, the 4" and 8" rotary table look no difference with others of other companies. But in fact, it has semi-industrial fuction and render machine higher machining accuracy. The work piece made by it has smoothy eadge and pricise angle. Please kindly see the picture. It is not only fit fot mini cnc aluminum alloy machine but also suitable for bigger indrustrial cast iron machine. However, it could meet your more precise machining need. We have two different size rotary table in stock, 4" and 8" for your different needs. All of them is with stepper/ servo motor. Do yu need motor for them? It is up to you. You could only buy rotary table without motor from us.
    If you would like to more information such as Diameter,Morse taper of the center hole, Diameter of the center hole and so on, please visit our website http://www.atron.com.tw or you could send me email to mill@diylife.com.tw.
    Attached Thumbnails Attached Thumbnails new rotary table for its special industrial function-22.jpg
    Banned
    Sep 2009
    china
    picture and specification for rotary table
    Because some friends write letter to me and ask for some detailed information of rotary table. To show it clearly, now I put them there for your kind reference.
    Attached Thumbnails Attached Thumbnails new rotary table for its special industrial function-whole_set_motorized_rotary_table_small_picture.bmp
    Attached Files Attached Files
    Banned
    Sep 2009
    china
    pictures
    Attached Thumbnails Attached Thumbnails new rotary table for its special industrial function-4_motorized_rotary_table.jpg   new rotary table for its special industrial function-whole_set_4_8of_motorized_rotary_table.jpg
    Banned
    Sep 2009
    china
    4" Rotary table with stepper motor ( 57 x 76mm, 3.0A ) x 1 set
    Specifications of Rotary table for 4":
    1. Diameter: 100mm
    2. Morse taper of the center hole: 2#
    3. Diameter of the center hole: 20mm x 8
    4. Height of center for Verti. mounting: 70mm
    5. Width of T-slot: 6mm
    6. Adjacent angle of T-slot: 90 degrees
    7. Width of the locating key: 10mm
    8. Modules of worm and worm gear: 1
    9. Transmission ratio of the worm gear: 1:72
    10. Graduation of the table: 360 degrees
    11. Readout of the hand wheel: 2
    12. Minimum value of vernier: 10"
    13. Indexing accuracy: 120"
    14. Max. bearing (with table Hor.): 20 KG
    15. Max. bearing (with table Vert.): 10KG
    16. Speed of table: 5 rpm
    17. Black lash for the table: 6 degrees
    18. N. W. : 7KG
    19. G. W. : 8KG
    20. Case dimensions: 245 x 165 x 112mm
    Banned
    Sep 2009
    china
    8" rotary table
    8" Rotary table with stepper motor ( 86 X 78mm, 4.0A ) x 1 set
    Specifications of Rotary table for 8":
    1. Diameter: 200mm
    2. Morse taper of the center hole: 3#
    3. Diameter of the center hole: 30mm x 6
    4. Height of center for Verti.mounting: 135mm
    5. Width of T-slot: 12mm
    7. Width of the locating key: 16mm
    8. Modules of worm and worm gear: 1.5
    9. Transmission ratio of the worm gear: 1:90
    10. Graducation of the table: 360 degress
    11. Rotating angle of table with one revolution of the worm: 4 degree (1 per graduation)
    13. Indexing accuracy: 80"
    14. Speed of table: 5 rpm
    15. Blacklash for the table: 6 degrees
    16. Max. bearing (with table Hor.): 50 KG
    17. Max. bearing (with table Vert.): 75KG
    Banned
    Sep 2009
    china
    A NEW ARM FOR HM-135 CNC MILING MACHIEN
    A new sample of hm-135 is nearly finshed in my office. We made some changes on the base of original machine. A new arm is mounted on the left side of machine as the attached pictures. Do you think it is needed or neccessory? It is about 1 meter from the ground to the arm. One steel(Q235A) tray is fixed on the arm. This tray is about 80cm length and 20cm width with one big slot and one small slot. So it maybe convinent for you to put keyboard on them preventing slipping. This arm has three joint to assure it turn 270 degrees from the machine side to the left door. You may ask what is vertical steel bar on the outside joint used for? It is for PC screen. In order to lowen cost, only one button is mounted on the controller box door. Small beautiful holes are drilled in the PC box door, tool box door and coolant box door in the machine back. If button or pulling rings are used, user maybe replace the damaged one during long using days.
    If you have any valuable advise, please contact me by mill@diylife.com.tw or skype: twhowmau012. You are also welcome to visite our web www.atron.com.tw for more information. We are about to introduce this new modal on our website and here both.
    Attached Thumbnails Attached Thumbnails new rotary table for its special industrial function-1.jpg   new rotary table for its special industrial function-2.jpg   new rotary table for its special industrial function-3.jpg   new rotary table for its special industrial function-4.jpg
    new rotary table for its special industrial function-5.jpg   new rotary table for its special industrial function-6.jpg
    Banned
    Sep 2009
    china
    more pictures about new hm-135 cnc milling machine
    more pictures about new hm-135 cnc milling machine.
    Attached Thumbnails Attached Thumbnails new rotary table for its special industrial function-7.jpg   new rotary table for its special industrial function-8.jpg   new rotary table for its special industrial function-9.jpg   new rotary table for its special industrial function-10.jpg
    Banned
    Sep 2009
    china
    PC on arm
    PC on arm could turn 360 degree. It render you working and looking at PC screen conveniently from many directions.
    Attached Thumbnails Attached Thumbnails new rotary table for its special industrial function-dsc02963.jpg   new rotary table for its special industrial function-dsc02964.jpg   new rotary table for its special industrial function-dsc02965.jpg   new rotary table for its special industrial function-dsc02970.jpg
    new rotary table for its special industrial function-dsc02972.jpg   new rotary table for its special industrial function-dsc02973.jpg
    Banned
    Sep 2009
    china
    Talking Electrostatic Painting
    To make first class cnc machine in the world, our factory inspected and used lots of procession technology.
    Last time I introduced laser cutting technology for sheet metal. Thanks for your attention to it. Please continuously pay your attention to electrostatic painting.
    Electrostatic painting principle is the same as electrostatic dust removal Its principle is that high-voltage forms electrostatic field carrying out painting. It is a new advanced painting technology. Compared to manual paint, it is of high efficiency, less waste, better quality and is conducive to the health of workers and so on. Paint is into the metal cup B of the high-speed through inputing tube. The spray paint emitted from cup is fogged due to atomized high-speed cup rotation. Fog spraying paint particles is with a negative charge due to rotation cup taking a negative pressure (60-120kV). Fog spraying paint particles repel each other and evenly spread out. Under the influence of the electric field force, paint particles flew to work piece taking positive charges and is adsorbed on the work surface to form a solid layer of bright light. Electrostatic painting due to the small scope does not pollute the air. At present, the electrostatic painting has been widely used in machine parts, such as processing of the train compartments.
    Electrostatic painting features are as following.
    1) The paint film is even, plump, both good adhesion and decorative.
    2) It is of high productivity. Multi-electrostatic spray guns are installed and are easy to semi-automated or automated implement as compared with the compressed air spray paint. The production efficiency can be increased several times.
    3) This new method could increase the utilization of paint up to 80 ~ 90%, reduce paint mist dispersion and pollution, and improving the working conditions of hygiene.
    The complex shape of the work piece, concave hole is not easy to spray to, convex tip is covered partly with uneven paint film. So during our painting process, we made adjustment or manual repair process to ensure work piece being painted evenly.
    Electrostatic painting maintenance and management is demanding. Improper operation or mismanagement will prone to electric shocks such as high-voltage breakdown discharge causing fire accidents.
    At present, all of our work pieces have used this technology. In this afternoon, I will go to electrostatic painting factory and took some photos. I am glad to share these photos with you here. If you have more advanced painting technology or other cnc machine procession, please share with us here and give your valuable advise.
    Sep 2005
    Indonesia
    Do you sell nc turret for lathe? What specs and price? Thanks.
    Banned
    Sep 2009
    china
    thanks for your inquiry
    Quote Originally Posted by asuratman View Post
    Hi asuratman, thanks very much for your interest in our products. Do you mean rotary table by turret. Yes we sell roatry table as you see in my privious threads. It is 4'' or 8'' available in stock. You could visite our web site for more detailed inforamtion. http://www.atron.com.tw/uwish/front/...ategory=111013
    It has semi-industrial fuction which could machine wood, plastic, aluminum and so on. Some work pieces are enclosed for your kind reference. Do you buy it for your own hobby use? Where is your councountry located? We are professional cnc machine manufacturer which has many cnc lathe mill and other standard accessories.
    If you are interested in any one accessoriy in our web, please kindly let me know that. I will give you the lowest price.
    Attached Thumbnails Attached Thumbnails new rotary table for its special industrial function-work_piece4_ss.jpg   new rotary table for its special industrial function-work_piece_3_ss.jpg   new rotary table for its special industrial function-factory2.jpg
    Banned
    Sep 2009
    china
    price for rotary table
    Hi asuratman. The price of rotary table is advertised in my below two threads.
    There are 4'' and 8'' two different kinds. Which do you prefer? Do you need to send to your detailed address?
  • Page 1 of 3 123 LastLast
    1. Industrial shevling/racking support for table?
      By eloid in forum DIY CNC Router Table Machines
      Last Post: 09-04-2009, 10:54 PM
    2. Need Help!- rotary table job
      By carlos1970 in forum Mastercam
      Last Post: 03-06-2009, 10:26 AM
    3. Help with rotary table
      By woodsnskins in forum Linear and Rotary Motion
      Last Post: 12-18-2008, 05:58 AM
    4. Industrial laser table recommendations please!
      By kennected in forum General Laser Engraving & Cutting Machine Discussion
      Last Post: 01-27-2007, 03:40 AM
    5. Industrial Vacuum table
      By osdhillon in forum DIY CNC Router Table Machines
      Last Post: 10-24-2005, 06:38 PM
