Wish all of you ,my dear friends a happy new year! I hope that all of businessmen in the world have a amazing gains and wonderful starting in the beautiful season.
We, TaiWan How-Mau Machinery Co.,Ltd. are almost engaged in promoting business with businessmen in the wolrd and sereve for everyone who have some special needs.
Now ,we stock for some new high perfomance cnc milling machines,HM-200,
some main features are introduced as follows,
1.This is one kind of High performance CNC milling machine;
2.The NC control system is Mach-3,In the self-made CNC engraving machine area, Mach-3 may be the best and most frequently used software .It costs fewer but process as perfectly as other big-ticket systems.
3.CNC control system could be adapted by step motor or servo motor, providing good cost-effective scheme to customers.
4.HM-200 machine can operate with NC program. With ballscrew, stepping motor for all 3 axes;
5.Position accuracy + or -0.0005''
6.Reproduction accuracy 0.00025”
7.With limit switch for all 3 axes.so it promise a safe condition for both man and the machine .
8.The tool material is HSS .It still maintain a high hardness when produces heat in the case of high-speed cutting (about 500 ℃), HRC can be over 60. This is the most important characteristics of high-speed steel.
9. Used for machining box parts, shell parts, disc-shaped parts. Almost all kinds of steel,wood,plastic can be machined.
10. Column and guide way is ground precisely with high precision.
11. Spindle is equipped manually, luckily ,our engineers are now designing new products equipped with tool-hit cylinder to make tool released and clamped pneumatically then Tool-change iwill be more safely and quickly.
12.it has a long-sevice life,and easy to be operated.
Specification
Model HM-200
Table travel x axis 22''
Saddle travel y axis 11“
Head travel z axis 11.5“
Table size 40''*12''
T-slot size 5/8''
Spindle taper R8
Spindle Bearings Angular Contact Bearings
spindle speed 150-4000 rpm
Motor hp rating 2 HP /1500W
Stepper motor(xyz axis) 1700 in-oz
Ball screw precision p5
Castings Castings
Work Cube 22”*13”*10.50”
Machine Dimension 36”*60”*84”
If you are also majored in this field or you are interested in this products ,are not satisfied with some points or have some good advice ,please do not hesitate to inform us.It's our honor to receive you kindly advice.
We also have some other goods in stock ,Welcome to our factory to have a visit,we'll supply you our best service.
http://www.atron.com.tw
Email: mill@diylife.com.tw
Tel : 86-632-5956607
Fax: 86-632-5956609
Skype :twhowmau015
MSN: david@diylife.com.tw
David
LinkBack URL
About LinkBacks
