Do you make these with Servo Motors and Encoders ??
We have new poduct for you:4" Rotary table with stepper motor ( 57 x 76mm, 3.0A ) x 1 set.Below are the specifications:
1. Diameter: 100mm
2. Morse taper of the center hole: 2#
3. Diameter of the center hole: 20mm x 8
4. Height of center for Verti.mounting: 70mm
5. Width of T-slot: 6mm
6. Adjacent angle of T-slot: 90 degrees
7. Width of the locating key: 10mm
8. Modules of worm and worm gear: 1
9. Transmission ratio of the worm gear: 1:72
10. Graducation of the table: 360 degress
11. Readout of the handwheel: 2
12. Minimum value of vernier: 10"
13. Indexing accuracy: 120"
14. Max. bearing (with table Hor.): 20 KG
15. Max. bearing (with table Vert.): 10KG
16. Speed of table: 5 rpm
17. Blacklash for the table: 6 degrees
18. N.W. : 7KG
19. G.W. : 8KG
20. Case dimensions: 245 x 165 x 112mm
I'll be glad to give you quotation if you need.
Toby D.
"Imagination and Memory are but one thing, but for divers considerations have divers names"
Schwarzwald
www.refractotech.com
If you like it.I suggest you make a quick decision.Course our company is in the Christmas promotion, 20% discount for all products.To buy any accessories you can enjoy more preferential.It's really a rare and precious opportunities.The price will go up to its normal amount after Chrismas,I suggest that you lose no time to seize the good chance.
Toby D.
Schwarzwald
I asked this question to our engineer.Yes,it can be compatible with Fanuc.Fanuc is ten times more than ordinary systems of the money.And it was usually used in industry area.For individual,ordinary system is OK.
Really thanks to your questions,I have acquired more knowledge.
