Jet Edge’s patented Dual Pressure Valve® greatly increases waterjet cutting productivity by allowing waterjet operators to control water pressure independent of the waterjet pump.
With the remotely-mounted Jet Edge Dual Pressure Valve, waterjet operators can run multiple waterjet tables simultaneously at various pressures with a single pump. Operators also can perform waterjet low-pressure piercing operations without waiting for the water jet pump to raise or lower to the desired pressure, saving time and reducing wear and tear on waterjet pump components.
The Jet Edge Dual Pressure Valve will operate with any manufacturer's waterjet pump, cutting head, or waterjet cutting system, and is fully configurable for pressure change ratios. Connection points are standard 60,000 psi-type. The Dual Pressure Valve is pneumatically operated and must be used in conjunction with another normally closed on/off valve or cutting head.
Customer Success Story
Creative Edge Master Shop, Inc. has greatly increased productivity and reduced maintenance with their Jet Edge Dual Pressure Valve.
Read Their Story Here.
More Information
For more information about the Jet Edge Dual Pressure Valve, visit www.jetedge.com, call 1-800-JET-EDGE (538-3343), 763-497-8700 or e-mail sales@jetedge.com
About Jet Edge
Established in 1984, Jet Edge is a global designer and manufacturer of waterjet systems for precision cutting, surface preparation and coating removal. Jet Edge waterjets are used around the world in a broad range of industries, from the world's leading airlines to automotive, aerospace, industrial manufacturers, machine and job shops. Jet Edge waterjet systems are proudly made in the U.S.A. For information about Jet Edge, visit www.jetedge.com, e-mail sales@jetedge.com or call 1-800-JET-EDGE (538-3343).
