Precision Plasma LLC is pleased to announce the release of a new heavy duty plasma table. Precision Plasma LLC is working on providing low cost, high quality CNC plasma tables for the hobbyist and small business owners. We only provide the mechanics of a system which allows the end user to choose the electronics and software that meet their needs. The table is compatible with nema 23 stepper motors.
Specifications:
- 5' x 5' cutting area
- Fully welded frame made from 3" x 3" tubing (powder coated)
- Aluminum gantry with hardened v-rails
- 3" travel Z axis with built in "float" for "touch and go" plasma cutting
- Belt reduction on X and Y axis (dual Y)
- Resolution of .0005" when using tenth step drives
- 1000 IPM rapid traverse
- Acceleration of 50in/sec/sec
Sample cut video:
"http://www.youtube.com/watch?v=AyhV4oLOHEg"]YouTube- Precision Plasma CNC Cutting Table
Belt reduction video:
"http://www.youtube.com/watch?v=xJiHwrJbwrM"]YouTube- Precision Plasma LLC Belt Reduction 50 IPM
"http://www.youtube.com/watch?v=ERB3w_Byd-s"]YouTube- Precision Plasma LLC Belt Reduction 1,000 IPM
Precision Plasma LLC sells a full line of DIY machines and kits ranging from 2' x 3' to 5' x 10'. Besides complete tables, we also will provide gantry kits for people looking to save more money. Contact me with your requests and I will be happy to offer you a kit to match your exact needs.
The 5' x 5' table kit shown above does not include anything but the frame, slats, gantry, Z axis, belt reduction units, and arm. Everything else needs to be sourced by the consumer. It requires (4) nema 23 stepper motors with 1/4" shafts with 276 in-oz torque or greater. Complete packages can be sourced from candcnc.com or many other vendors on the web.
In order to keep costs low, Precision Plasma LLC has chosen not to sell the electronics or motors with the machines. The support for the mechanics of the table is provided by Precision Plasma LLC. Support for the electronics must be sourced from the vendor which you purchase from. If you don't require support, you can piece together an electronics package with torch height control for under $1,000. If you require support, I suggest purchasing a complete package from candcnc.com for around $1,400.
Cost:
5' x 5" DIY table $4,500 + crate & shipping if required
Best Regards,
Ron Chacich
info@precisionplasmallc.com
