Page 1 of 2 12 LastLast
Results 1 to 12 of 15
Thread: New 4 axis G540 controller
    Oct 2005
    Here is our new 4 axis G540 controller
    One G540 4 Axis
    one KL-600-48 48V/12.5A 115V /230V power supply
    One Fan
    One E-Stop, X, Y, Z Limit Switch
    If you have any question, pls email me at support@kelinginc.net
    http://www.kelinginc.net/ControlSystem.html
    Attached Thumbnails Attached Thumbnails New 4 axis G540 controller-g540controller.jpg
    Jul 2010
    Poorly Assembled Product
    I recently purchased purchased this Controller Box from Keling. It's very poorly assembled. Here are the problems I discovered:
    1) The E-Stop button was wired up backwards, in a normally open configuration. Nothing would work until I pushed the button IN.
    2) There is no connection of any kind to the GROUND tab on the AC power jack. Neither from the ground connector on the power supply or the case itself. If something shorts to the case it will make it live.
    3) The DB9 connector provided for hooking up limit switches cannot be used as wired as none of the pins are wired to ground, terminal 12 on the G540 or -VDC on the power supply. All Keling did was to wire terminals 1 - 9 of the G540 to the pins, and not in any logical order. There is no documentation of any kind provided on the pin configuration either with the product or on the site.
    4) The soldering job is very heavy handed and sloppy. There were a number of connections with little frayed wires coming dangerously close to cross circuiting the pins. No shrink wrap or other insulation was used to prevent accidental cross circuiting.
    5) Most of the hardware connections (nuts and bolts) are only finger tight. The heavy power supply was so loose and floppy it almost fell out of the box when I opened it up.
    Repeated emails to Keling for technical support yielded only half sentence responses which failed to answer my questions. Oh, the one complete sentence was "Contact support@geckodrive.com for the answer." Which I understand is a fairly typical response from Keling. At least Gecko was helpful in letting me know how to rewire so I could hook up limit switches.
    It's all working fine now, but not without several hours of my own time troubleshooting and re-wireing. It's far from the "Plug and Use" as advertised on the Keling site. Also, it's obvious, with all these problems (especially the E-Stop mis-wiring) that the box was never tested with Mach 3 (as advertised) to see if it's functioning properly. If your considering purchasing this box, I'd strongly advise just buying the individual components and following one of the helpful schematics that can be found on the CNCzone.
    Oct 2005
    Quote Originally Posted by dpgoldberg View Post
    Hello
    I failed to make you happy, pls ship back, we will 100% refund to you
    Feb 2007
    canada
    This should be just a Mach3 configuration setting. Nothing wrong using N/O for the stop switch.
    Manufacturer of CNC routers and Viper Servo Drives
    www.LarkenCNC.com and www.Viperservo.com
    Registered LatheMaster's Avatar
    Sep 2009
    Keling ,
    It would be real nice if you sold the box , switches and IEC plug-ins on your site as separate items . Or some type of builders kit that we put together .
    Mar 2012
    Thanks dpgoldberg, very helpful.
    Feb 2007
    Cool
    Quote Originally Posted by Larken View Post
    Not very safe if there is a break (open) in the wire somewhere, the machine will start but you wont be able to estop. outch!
    Oct 2005
    Quote Originally Posted by Claude Boudreau View Post
    This G540 box is made as following now
    check the link
    http://www.automationtechnologiesinc...h-power-outlet
    Attached Thumbnails Attached Thumbnails New 4 axis G540 controller-g540box-back-500x500.jpg   New 4 axis G540 controller-controller-box-150x150.jpg
    Feb 2007
    Quote Originally Posted by Kelinginc View Post
    check the link
    http://www.automationtechnologiesinc...nce=4387d768f6
    unable to open that link
    Oct 2005
    Check this link
    Feb 2007
    Oct 2005
  • Page 1 of 2 12 LastLast
    1. Config for 2 motors on x-axis (w/ Gecko g540)
      By rogerer in forum LinuxCNC (formerly EMC2)
      Last Post: 05-16-2009, 10:30 PM
    2. Newbie- G540 + 4 axis Isel?
      By Eligius in forum Gecko Drives
      Last Post: 04-27-2009, 11:32 AM
    3. 8 axis 48V 12A G540 system
      By dmauch in forum Gecko Drives
      Last Post: 04-05-2009, 12:04 PM
    4. g540 y axis problem
      By meck11 in forum Gecko Drives
      Last Post: 03-31-2009, 03:57 PM
    5. NEW G540 4 Axis Package
      By Kelinginc in forum Automation Technology Products
      Last Post: 08-08-2008, 03:27 PM
