Brownpolymer is a MUPS a (Multi use Polymer Substance). Uses are protective coatings to prevents rust or corrosion. will stop acid from attacking a surface. Won't wash or wipe off , Most solvents won't remove it. Excellent lube for drilling hard or soft metals. been used in the jewelry trade for years. Developed for metal spinning as a high speed and pressure lube. Can be used as a dry or wet lube.
Has been used a way lube, gear and bearing lube, Polishing aid, protective coating for tools tooling and equipment, gun lube and bore butter.
This is a new polymer developed by accident and is non toxic and can only me removed by turpentine
Thanks Randy
AKA Enjen Joes Products
