Results 1 to 5 of 5
Thread: AxiomVE™ obsoletes ALL other nesting and programming technology.
    Aug 2008
    Optimation® once again has proved it's the leadership in the industry with the release of AxiomVE™. AxiomVE™ obsoletes ALL other nesting technology in two important ways.
    Vision Emulation™ is what VE stands for. Vision Emulation™ is a new and exclusive technology invented by Optimation®. This new technology allows AxiomVE™ to "see" the shape of the part and "see" the shape of the available material and select the best part at the optimal angle. Previously, nesting systems had to rotate parts in small increments and try to fit the part after each rotation. This is time consuming and leads to wrong results. Some of our competitors brag about rotating parts at one degree increments. That type of trial and error nesting is now obsolete. AxiomVE™ looks at the part and determines without trial and error the optimal rotation. A part may need to be rotated 124.372 degrees to fit optimally. AxiomVE™ determines that optimal rotation without undo trial and error.
    Backing up Vision Emulation™ is a new Multi-Dimensional-Combinatorial-Nesting™ technology (MDCN™). This new technology transcends previous nesting methods. Until MDCN™, most nesting algorithms were simple heuristics. Optimation® is the only company that has developed a nesting technology that considers the alternatives and guarantees the highest efficiency while insuring that production schedule and priorities are optimized. Standard Heuristics crash badly when presented with real world problems. MDCN™ looks at many different dimensions that affect cost. Schedule, hot parts, material efficiency, order completion, tool optimization, common cutting, torch load and many other costs make finding the optimal nest Multi-Dimensional. Considering all of these costs while finding the right combination of parts is what makes MDCN™ so powerful.
    www.optinest.com/cd
    Combining MDCN™ and Vision Emulation™ makes AxiomVE™ the most powerful nesting system in the world.
    sbooty@optinest.com
    www.optinest.com
    Aug 2008
    Nesting and programming to "real world" situations is NOW available, for real.
    Optimation's Axiom VE is the only software that can give you the parts you want, when you need them, in your real world situation. And, this wil be accomplished with operating more machines and combination processes to their maximum capacity than any other software will allow.
    We utilize Multi-Dimensional, Combinatorial Nesting and Vision Emulation to achieve what no other company can.
    We are ready to be put to the test. Bring what ever you are using now. It will be beat. No other software has this technology and we want to show you the ECONOMIC REALITIES.
    Scott
    Contact Me at: sbooty@optinest.com
    www.optinest.com/cd
    Optimation®
    May 2007
    us
    Sbooty, how does one determine if Axiom VE is installed?
    Aug 2008
    jimbobk1,
    Axiom VE is the nesting engine. When we install the software Axiom VE is automatically installed as part of the total package.
    Did that answer your question?
    Scott
    sbooty@optinest.com
    www.optinest.com/cd
    Aug 2008
    Advanced Technology
    Axiom VE is the only software that has Vision Emulation, and combined with our Multi-Dimionsional Combinatorial Nesting, it is the only software that allows you to get the parts you want, when you want them. This is true dynamic nesting according to "your real world situation".
    Scott
    sbooty@optinest.com
    www.optinest.com/cd
    1. Just IN- Advancement in Nesting Technology - Vision Emulation
      By Optimation in forum Product and Manufacturer Announcements
      Last Post: 09-05-2008, 02:19 AM
    2. X3 nesting
      By foxsquirrel in forum Mastercam
      Last Post: 08-11-2008, 11:03 PM
    3. 2D On-Line nesting - Nesting on-demand !
      By mijo in forum Product and Manufacturer Announcements
      Last Post: 03-21-2006, 10:42 AM
    4. nesting
      By coolman in forum PTC Pro/Manufacture
      Last Post: 04-16-2005, 05:37 AM
    5. nesting
      By georgebarr in forum Visual Mill
      Last Post: 03-15-2004, 09:59 PM
