Is there an english version?
Nice! I'll transfer that to my CNC computer and use it as background. Maybe my Czech mill will feel better after I tore out it's guts and put in ballscrews and hung on steppers.![]()
Yes English version is in.
Jazyk(Language) - > Czech, English
Badatel,
The program crashes on my system. I points to another directory (not there) and .txt file. Then it causes a page fault and crash.
Win 98
PIII
Chris
You must download version v1.4.7 and install. Next unzip file version 1.4.8.3
Badatel
I tried it as you stated; however, there is still some problems with the english part. Not all words have changed translation. Also, is there a chance that this program supports inch measurement?
Supports inch measurement will have next version (1.5)
I downloaded it and it seems promissing. The 1.4.8.3 zip doesn't open though. The english translation is indeed incomplete, so it's not easy to learn how to use it. We could also edit the eng.lng file to correct the problem if someone posted the translation of the remaining Czech menus or I find a Czech dictionary.
I've also started translating to Greek (nice feature beeing able to add languages). An english version of the help files would also be great.
The more I use it the more I like it. I can't wait for the language problem to be fixed.
I had some progress with the Greek translation (I even used an online Czech dictionary). I'll take it to work and if the serial transfer works then there's nothing more I could ask for.
Two pics of my first tests: a 3d model of a CPU water cooler and the toolpath simulation for the same part (minus the drill cycle).
Works ok here. Thanks a lot for your effort. It could be useful. Even more useful when the translation gets complete.
Mats
I'm really looking forward to working with this when the translations are done. Thank you very much!
Software For Metalworking
http://closetolerancesoftware.com
