Page 1 of 2 12 LastLast
Results 1 to 12 of 20
Thread: A BETTER TAP WRENCH! SELF CENTERING!
    Jan 2006
    united states
    I would like to announce a push we are making at Northern Machining Inc. to try and test the marketability of our improved tap wrench.
    Please visit the following link for more info: http://cgi.ebay.com/ws/eBayISAPI.dll...X:NEWLIST#LIST
    To check out a video showing how it could be used in a milling machine, or drill press. http://northernmachininginc.com/tap%20demo.html
    The most important realization to make, is that this design keeps the tap centered with the spindle in the machine. Not all taps come with a center hole for supporting the tap when running it in by hand, with a tap wrench. This causes one to try and tap without proper upper support and many times can result in a broken tap which can not only be expensive for the cost of the tap, but also can leave the broken tap in the part that is being worked on, which in alot of cases can only be removed with the use of an EDM which can be a very expensive process.
    Our wrench gives multiple options for the upper support needed to remove risk of breaking a tap!
    Thanks for taking the time to check out our product, and any suggestions or comments are welcome!
    Regards,
    Chad Ashley
    chad@northernmachininginc.com
    Jul 2004
    You better put that video on u tube or you will eat up the transfer allowance on the site in a big hurry. Neat handle.
    On all equipment there are 2 levers...
    Lever "A", and Lever F'in "B"
    Jan 2006
    united states
    Quote Originally Posted by DSL PWR View Post
    I took your advice and did put it on Youtube.com
    Here is the link:
    "http://www.youtube.com/watch?v=s7K4R1ia4L4"]YouTube - Unique Tap Wrench! SAVES MONEY IN LONG RUN!
    Jan 2006
    united states
    I am really looking for some feedback if anyone would be kind enough to reply. Anything is welcome!
    Thanks,
    Chad
    May 2007
    It looks like a nice well thought out tool. If I did any amount of tapping I would probably get one. I might anyways.
    Jan 2006
    united states
    Quote Originally Posted by lowpull View Post
    Thanks for the positive feedback. I am very curious as to what people think of the price. Would you say that because of the benefits that our tap wrench offers over others, it is worth the cost $89.95? Our wrench is around the cost of the higher end tap wrench's like Starrett, or Snap On, but does more to help eliminate the chance for tap breakage.
    Chad
    Dec 2003
    Are these available yet or do you have initial assessment versions one can purchase?
    Monkeywrench Technician DareBee's Avatar
    Jan 2004
    Stratford, Ont. Canada
    I see great benefit to the person that is using it centered over the hole under a machine spindle. Although, I almost always power tap.
    I can see no benefit to the person that is tapping on a bench or on a job site, which is where myself and my employees tend to use tap wrenches.
    Appears to be a good product and you should have respectable sales with it.
    www.integratedmechanical.ca
    Jan 2006
    united states
    Quote Originally Posted by Al_The_Man View Post
    Yes, these are available and I am pointing anyone interested to the following ebay site because this person has been a huge help in trying to market these for us. We have been testing a wrench now for over 4 yrs. and have not had any problems, and the hardened jaws hold up very well without deformation.
    http://cgi.ebay.com/Tap-Reamer-Wrenc...QQcmdZViewItem
    Thanks,
    Chad
    Jan 2006
    united states
    Quote Originally Posted by DareBee View Post
    Your are exactly right in that, it does have a huge benefit for those that tap using the spindle of a milling machine or even a small drill press which many homeowners have in there garage or basement. Also there is no benefit when it comes to bench use or on the field, except that our parts are all replaceable and the jaws are hardened.
    I appreciate your feedback!
    Chad
    Registered cadmonkey's Avatar
    Mar 2006
    I like the low profile as it is annoying to raise/lower for the other style tool which I have and you showed, but the price is too high for that convenience and the amount of tapping I do and the accuracy required for most of it. The wide capacity range is nice (#80 - 1/2").
    I don't want to insult you with what I would be willing to pay for it, even considering it is obviously made in the USA (which does count for a lot with me).
    Every day is a learning process, whether you remember yesterday or not is the hard part.
    www.distinctperspectives.com
    Oct 2005
    It is an interesting design. I probably wouldn't buy it though. When I tap with my mill, I use power, and when I tap at the bench I like a long thoated version over a T handle. It may have a market from the guys that want/need an "Oh WOW" tool in their box.
  • Page 1 of 2 12 LastLast
    1. Looking for someone or someplace to sell our tap wrench
      By northernmach in forum CNCzone Club House
      Last Post: 03-18-2008, 06:48 AM
    2. Box Wrench for Leveling Feet
      By Donkey Hotey in forum Haas Mills
      Last Post: 01-04-2008, 07:58 AM
    3. Wrench machining
      By wildcat in forum Employment Opportunity
      Last Post: 09-19-2007, 06:15 PM
    4. X-3 Spindle wrench
      By DICKEYBIRD in forum Benchtop Machines
      Last Post: 12-26-2006, 06:20 PM
    5. NMTB30 wrench / spanner?
      By damae in forum Bridgeport and Hardinge Mills
      Last Post: 12-14-2005, 04:45 PM
