Results 1 to 7 of 7
Thread: SpiderCool...
    Aug 2007
    SpiderCool...
    True Testimonial from Parker Hannifin Corporation:
    “Before installing SpiderCool, our high-speed drill / tap machine with 2200 IPM rapids and .7-second tool change, was severely limited by inefficient coolant distribution. Due to widely differing tool lengths, and expensive special form cutters, we were forced to manually adjust the coolant loc-lines after many operations. It is impossible for us to provide enough loc-lines to cover the number of tools we use.”
    “SpiderCool has eliminated this problem and improved cycle time by 40%”
    ______________________________________________
    The SpiderCool system is a programmable coolant nozzle that automatically aims a higher volume coolant stream at the cutting edge of every tool, regardless of length, loaded into the spindle of any vertical or horizontal machining center by the tool changer. We refer to the system as "programmable," but "teachable" is a more descriptive term because the nozzle positions are actually set and memorized by using the servo adjustment knob conveniently located on the machine's control panel. "G Codes" or "M Codes" are not used.
    By eliminating manual coolant adjustments, machining centers can run without operator intervention for extended periods of time, which greatly improves cycle efficiency and yields more profit per machine hour.
    Coolant is precisely aimed at the cutting edge where destructive heat is generated. Eliminating multiple "loc-lines" increases coolant velocity, and provides more coolant to the cutting edge. Chip flushing is substantially improved as well...
    Time wasted adjusting coolant lines is eliminated. SpiderCool can be adjusted during setup, and while cutting. Because tool life is increased, time spent changing worn tooling and re-setting tool offsets is significantly decreased.
    ProductionPal is offering the standard SpiderCool sytem at $1,995.00.
    Contact productionpal@gmail.com or visit
    http://productionpal.googlepages.com/home
    Aug 2007
    Pictures
    pictures...
    Attached Thumbnails Attached Thumbnails SpiderCool...-spidercool1.jpg   SpiderCool...-spidercool2.jpg
    Aug 2007
    Video of SpiderCool in action and then SpiderCool partnered with an Accu-lube MQL(Minimun Quantity Machining)...
    http://www.neardrymachining.com/Vide...rCoolShort.wmv
    Aug 2007
    Bump...
    Still offering....
    Registered single phase's Avatar
    Feb 2006
    Pennsylvania
    I am interested because I machine titanium and I do not have through coolant. Normally I use 20 tools and drill some 4D to 8D holes.
    I have a Milltronics VM-15 vintage 1998 with a Centurion 6 control. How could the Spidercool get tool information from it?
    Cheers
    SF
    Aug 2007
    I sent you a private message explaining a little...thanks for the interest!
    Aug 2007
    Thanks for the purchase Singlephase...and thanks for the honest review in the Milltronics section.
    Jaime M. Boxell Productionpal, Inc. Authorized Distributor of SpiderCool Systems
    (763) 412-5486 or productionpal@gmail.com http://productionpal.googlepages.com/home
    1. Programmable Coolant Nozzle-SpiderCool
      By ProductionPal in forum Product and Manufacturer Announcements
      Last Post: 10-25-2007, 10:49 AM
