LY-A Zhongneng Vacuum Automation Lubricating Oil Purifier
Application
Series LY-A is special for purifying all kinds of lubricating oil such as the hydraulic oil, mechanical oil, coolant oil, gear oil, and heat treatment oil and so on. This machine can operate automatically (don’t need the person when it is working). According to the lubricating oil’s nature, this machine can rapidly remove water, gas, particulate matters and impurities from lubrication oil, so guarantee lubricating system of machine to work properly and prolong lifetime of machine.
Features
1. Strong capability of breaking emulsification.
2. The combination of coalescing separation and vacuum dewatering.
3. More Deeply and precisely FH rectangle filtering system. The oil will reach to the new oil’s nature when it was purified.
4. Zhongneng’s unique technology with H.P.M high molecule absorption material.
5. The automatic system of advance infrared liquid-level, the automatic safeguard system of pressure, and the automatic system of temperature constancy the automatic safeguard system of electricity Operation is simple, safe and reliable.
LY-R Zhongneng Vacuum Lubricating Oil Regeneration Purifier
Application
Series LY-R which add a regeneration device is special for purifying all kinds of lubricating oil such as the hydraulic oil, mechanical oil, coolant oil, gear oil, and heat treatment oil and so on.. this machine can not only rapidly remove water, gas and impurities from lubrication oil, but also remove the free carbon, deep oxides, acid, pitch. So it can highly boost the oil's value, making the oil more suitable for the lubricating system.
Features
1.Strong capability of breaking emulsification.
2.The combination of coalescing separation and vacuum dewatering.
3.More Deeply and precisely FH rectangle filtering system. The oil will reach to the new oil's nature when it was purified.
4.Zhongneng's unique technology with H.P.M high molecule absorption material.
5.Besides the common vacuum oil purifier's function of dewatering, degassing and eliminating impurities, this machine can regenerate the seriously deteriorated oil by removing the polarity materials, such as the deep oxides, free carbon in the oil effectively.
