Results 1 to 10 of 10
Thread: Textgraver Software free!
    Registered dubble's Avatar
    Oct 2006
    Hungary, European Union
    Wink Textgraver Software free!
    We wrote a small program, which generates G-code from any TTF (true type fonts).
    Under XP, just place the special font files to .../windows/fonts/... library and you can engrave text with your new fontset from Mach or other CNC controller software.
    The software is completely free to use, we wrote it just for fun and help the CNC community.
    Download it here: http://www.cncdrive.com (at the download section)
    Mar 2005
    U.S.
    This looks really neat. Are the units in mm? is there a way to change them to inches? Thanks!
    Oct 2006
    Thanks.
    I think it's no problem if it's in mm's or inches, it's in Units.
    When you load it e.g. into MACH, one unit will be 1, so it depends on only how did you set up MACH, inches or mm's.
    There's no explanition in G-codes for unit type!
    I hope you get the idea.
    Try to load the generated code into MACH and you will understand, I think.
    Regards,
    Balazs
    Registered neilw20's Avatar
    Jun 2007
    Metric?
    I supose (LOL)
    Programming in Inches requires more horsepower and more material.
    Programming in mm requires more killowatts and less material.
    Super X3. 3600rpm. Sheridan 6"x24" Lathe + more. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
    Jan 2007
    Sweden
    Hello !
    This was a very nice prg. Did som "wingdings" in a copperplate. Just one question, How can I engrave mirror text? Is there any option to get the text in mirror ?
    Sorry if this is a stupide question, I'm not so good at this but learning....
    Greatings,
    Bengt
    (Sweden)
    Oct 2006
    Thanks for the appritiation.
    No, it's not a stupid question, it's a very good question.
    There's no option, yet to mirror the text, the only reason is that it wasn't in my mind to code that into the program.
    I will make this option, as soon as I will have some freetime.
    Thanks for the idea, it will make the program more comfortable.
    Regards,
    Balazs
    Jan 2007
    Sweden
    Thanks for your answer.
    Again, this prg is super, so easy to use an to make a plexi screen it has everything and is quick and easy to use. I was thinking if the machin has mirrored x-axis the text will be right engraved on a copperplate I guess.... or... Am I thinking wrong?
    Greetings
    Bengt
    Jun 2007
    Wink scale X or y axis by -1.
    Quote Originally Posted by bengt View Post
    Greetings
    Bengt
    Scale X or Y axis by -1 will mirror.
    Jan 2007
    Sweden
    Thanks neilw20, I will try this later tonight
    greetings,
    Bengt
    Oct 2006
    Quote Originally Posted by neilw20 View Post
    Yes, you are absolutely right, it will do mirroring.
    Regards,
    Balazs
    1. Free Software
      By CNCRob in forum General CAM Discussion
      Last Post: 12-31-2012, 08:53 AM
    2. Free Doors--Free Cabinet Door Software
      By 1BigPig in forum General CNC (Mill and Lathe) Control Software (NC)
      Last Post: 06-07-2007, 02:36 PM
    3. First post in the software dept. Free cnc software?
      By runinbymdnt in forum General CNC (Mill and Lathe) Control Software (NC)
      Last Post: 02-06-2007, 10:49 PM
    4. Free CNC software, anybody seen this?
      By gboss30 in forum General CAM Discussion
      Last Post: 06-02-2003, 02:28 PM
