VFD-Double-Stage High-Efficiency Vacuum Insulation Oil Purifier
Application
VFD series is mainly used to improve the properties of insulation oil. It can remove trace water, gas, particulate matters etc. from the insulating oil effectively and rapidly so as to boost performance of transformers, circuit breakers, mutual inductors, cable and capacitors which has insulation system. VFD series specialize in purifying branded oil, insulating oil of high voltage and super high voltage transformer. Additionally, it is suitable for treating low viscosity lubrication oil.
Brief Introduction
Sino-NSH Oil Purifier Manufacture Co., Ltd is a high-tech Company which is engaged in researching, developing and manufacturing lubrication purification equipment.
NSH oil purification equipment series are extensively used in the fields of electric power, petroleum, natural gas, mechanical manufacture, steel, metallurgy, railway, aviation etc. which consume lubrication oil.
Product Catalogue
Insulation Oil Series
VFD Double-Stage High-Efficiency Vacuum Insulation Oil Purifier
VFD-A Double-Stage Vacuum Insulation Oil Automation Purifier
VFD-R Double-Stage Vacuum Insulation Oil Regeneration Purifier
VFD-T Double-Stage Vacuum Insulation Oil Purifier with Tester
Turbine Oil series
TF Turbine Oil Purifier
TF-A Turbine Oil Automation Purifier
TF-R Turbine Oil Regeneration Purifier
Lubrication Oil series
LV Lubrication Oil Purifier
LV-A Lubrication Oil Automation Purifier
LV-R Lubrication Oil Regeneration Purifier
Gas Engine Oil Regeneration System
GER Series
Contact: Anemone Tang
SINO-NSH oil purifier manufacture Co.,Ltd
EMAIL: sinonsh11@vip.163.com
TEL: 0086-23-67725736
FAX: 0086-23-67725653
URL:http://www.supplierlist.com/b2b/sinonsh11/profile.htm
ADD: NanQiaoSi,JiangBeiDistrict,Chongqing P.R.C
