Application:
IIJ-II series fully automatic oil tester is designed as per the requirement of IEC165 Testing Method of Insulation Oil Medium Strength, which via proper programming, has got functions of auto boosting, step down, stirring, display and print out. After breakdown of oil medium, HV break off will operate within 10 seconds to enable an auto isolation of control system partly; this effectively safeguards the personnel security and equipment safety. The tester is suitable for testing of the strength of insulation oil medium, as well as for testing of withstand voltage of transformer oil.
Feature:
1) Fully automatic, control by microcomputer, utilization of new I/O terminal.
2) Numbers of times of testing and idling time of stirring are set via digital sitting.
3) Test results displayed and printed out automatically.
4) Strong capability of anti-interference
5) High accuracy of testing.
6) Easy to operate, small size, light weight and convenient for maintenance
Mr. colin zhang
Chongqing Jinrun Machinery Electron Co.,Ltd
Http://www.jrcq.com
Tel:0086-023-89663793
Mob:0086-13018397891
Email:colin4427zlm@163.com
