Results 1 to 4 of 4
Thread: BLDC Machine Tool Motors
    Dec 2010
    New Zealand
    Hi all! I'm pleased to bring a new range of BLDC motors to market. Adlee Powertonic produce some very fine motors - certainly reaches above mainland China's offerings! I've personally been using them for a couple of years now, and found them to be Industrially reliable. They're general purpose prime-movers and not specific machine tool motors, but none the less work very well on metal work machinery.
    Generally, Adlee greatly under-rates their motors. They're tested in 40c ambient temps, so an average temp of 20c should see higher achievable ratings.
    All motors have these features in common:
    - Mach 3 compatible - works with most speed control boards (tested with CNC4PC C6)
    - Fully programmable settings (Accel, Decel, P gain, I gain, plus many others)
    - Built-in overheat protection (100c cut out).
    - Stall/Overload Protection
    - MODBUS Compatible (haven't tested this feature).
    I've evaluated some motors and found 3 models that should be of interest to the hobby / light production crowd:
    AM370-H, 370watt rated, 1100watt MAX, 6000RPM. Available in 110v or 220v options (not dual voltage, +/- 10%). It's a likely drop-in replacement for the Seig SX3 machine (except the control panel). It should give you slightly more power and the ability to interface with MACH3 (via speed control board). It'd be a good match for the Sieg X2 or Optimum BF16/WMD20 mills and small-medium sized hobby lathes (100-200kg, 220-440lbs). Weight approx 4kg (9lbs). .
    AM1000-H, 1000watt rated, 2300watt MAX, 6000rpm. Available in 220v ONLY (+/- 10%). A good match for Seig X3 machines, Weiss WMD20/25, Grizzly G0704 machines with power to spare. 130mm X 130mm frame. Weight approx 9kg (20lbs).
    AM2200-H, 2200watt rated, 4000watt MAX, 6000rpm. Available in 220v ONLY (+/- 10%). This is the largest BLDC motor Adlee produce. This motor would be a good choice for those with heavier mills - RF45 style, Knee Mills & the like. I've noticed some people have had issues with Novakon and Makini spindle motors - these should be more than adequate for these machines. 130mm X 130mm frame. Weight approx 11kg (24lbs).
    Pricing:
    Currency in NEW ZEALAND dollars (click link for conversion)
    AM370-H Set - $649.00 NZD +$150 intl shipping (GBP, Euro, USD, AUD)
    AM1000-H - $899.00 +$275 intl Shipping (GBP, Euro, USD, AUD)
    AM2200-H - $1149.00 +$275 intl Shipping (GBP, Euro, USD, AUD)
    Australian customers receive 50% shipping reduction (due to their proximity).
    More info on my homepage:
    www.homemachineshop.co.nz
    AM370-H / D305 manual
    BL2-AM1000/2200 manual
    Also to come are some CNC Kits for the Weiss WMD20/25, Grizzly G0704 machine and other BF20 clones, plus other accessories.
    Dec 2010
    New Zealand
    AM370 Installed on Weiss WMD25LV
    AM1500 Installed on Weiss WMD25LV
    Feb 2010
    Would be interested in converting my Novacon NM145 to AM2200-H.
    Has any of you guys done this?
    Dec 2010
    New Zealand
    I've had enquiries about an NM145 machine. From the images I've been sent it looks like you'd need to make mounting hardware first, and probably bore out the motor pulley to 24mm.
    The motor is a fair bit larger, so it wouldn't be a "drop in" replacement, but its certainly doable. The Am2200 would have plenty of power for that machine.
  1. Replies: 4
    Last Post: 02-01-2011, 09:10 AM
  2. GD Tools and BLDC Motors
    By Lapin in forum Granite Devices
    Last Post: 03-25-2010, 02:54 PM
  3. Bldc motor and controller is used in the mini machine
    By wang in forum Product and Manufacturer Announcements
    Last Post: 09-19-2009, 08:05 AM
  4. 3-phase bldc motors
    By haroldj in forum General Electronics Discussion
    Last Post: 03-14-2008, 07:01 PM
  5. Speed control (not a servo amp) for BLDC motors?
    By Zumba in forum Servo Motors and Drives
    Last Post: 06-19-2007, 09:05 AM
