Results 1 to 3 of 3
Thread: The Game Has Changed - Wilson Tool EXP
    Jan 2012
    Punch press tooling just got more productive, more durable and more affordable.
    Introducing EXP™ punch technology from Wilson Tool International®, the first tooling in the industry to offer a standard holder with truly universal punches.
    Another innovative product from the experts in punch press tooling, EXP punch technology for thick turret punch presses increases productivity, reduces manufacturing waste, saves storage space and delivers better performance, grind-life and durability than our ground-breaking HP punch press tooling at a lower cost.
    Make the Switch to Universal Punches.
    Why replace an entire punch assembly when all you need is a different punch? The revolutionary EXP punch technology makes it practical and cost effective to only replace the punch.
    Wilson Tool offers EXP punch holders designed to fit in all styles of A and B station thick turret assemblies. Simply replace your current punch with the EXP punch holder and you're ready to use the EXP punch. EXP punches can be ordered in a vast array of configurations, including rounds, shapes and specials to suit virtually any need.
    Set Up Four Times Faster.
    EXP punch technology offers the fastest setups in the industry. Switching between punches is up to four times faster than changing traditional punch press tooling.
    Loading EXP punches is as easy as pushing a universal punch into the punch holder, then turning the key to lock it in place. To remove a punch, simply turn the key to unlock and pull the punch out of the holder. Switching from one punch to the next can be done in seconds, significantly reducing downtime.
    One Punch Technology for All.
    EXP punch technology is available for all major brands of thick turret tooling. No matter what type of thick turret tooling you use, EXP punch technology is fully compatible with all current guide assemblies.
    For shops that run more than one type of thick turret tooling, EXP punch technology eliminates the need to buy punches from multiple manufacturers. Instead, you'll be able to stock a greater selection of punches that can be used throughout your shop.
    Better Tool Steel for Longer Tool Life.
    No other punch press tooling offers longer tool life than EXP punch technology. Every EXP punch is manufactured with Wilson Tool's exclusive Ultima™ premium tool steel to increase wear resistance. As a result, EXP punches have twice the tool life as most standard punches.
    Stock More. Store Less.
    A fraction of the size of standard punches, EXP punches give you the flexibility to stock more shapes, using less space for storage. With a smaller footprint required for storage, your operators can increase productivity by keeping the punches they need close at hand.
    Expect More for Less.
    EXP punch technology is quite simply better tooling for less money. Because EXP punches require significantly less material and produce less waste, manufacturing costs are reduced. We're able to pass those savings on to you. A lower punch price combined with faster setups, stronger tool steel and greater versatility makes EXP punch technology the best value for your money.
    Watch the EXP Introduction Video > http: //www.youtube.com/watch?v=zVjC8cDlyqY
    Contact salesdesk@wilsontool.com
    Attached Thumbnails Attached Thumbnails The Game Has Changed - Wilson Tool EXP-img_01.jpg   The Game Has Changed - Wilson Tool EXP-img_02.jpg   The Game Has Changed - Wilson Tool EXP-img_03.jpg   The Game Has Changed - Wilson Tool EXP-img_04.jpg
    Registered carbidecraters's Avatar
    Apr 2005
    Bump for the big "W"
    We have had good luck with our Fadals milling mostly soft steel and aluminum up to 5 axis. We are always looking for spare parts :) If you have a broken down Fadal give a shout.
    Nov 2006
    Scotland
    We run Wilson Tooling in our LVD punch press here in the UK.Top quality stuff and first class service.
  1. Getting back into the game
    By blvdbuzzar in forum DIY CNC Router Table Machines
    Last Post: 10-26-2010, 07:30 PM
  2. Changed My Tool Storage...
    By Dave's_Not_Here in forum Techno CNC
    Last Post: 09-03-2010, 12:58 AM
  3. Game pad controller
    By plateroomred in forum CamSoft Products
    Last Post: 06-17-2005, 02:23 PM
