Price/Performance Breakthrough!
The MultiCam Value Series Waterjet is a smart CNC investment that’s easy on the budget with a price point in the $80,000 range. “We designed the V-Series Waterjet to offer high performance, versatility and productivity at an affordable price,” said MultiCam Inc. Director of Sales and Marketing, John Harris. “It’s easy on the budget and a smart CNC (computer numerical control) investment.”
The V-Series Waterjet has enclosed bellows to protect the Y and Z axes from abrasive garnet build-up. In addition, steel covers are built-in to keep dual drives and all X-axis precision bearing surfaces clean during the cutting process.
NEOLine Pump Options:
The V-Series Waterjet can be paired with a KMT NEOLine 40i Intensifier, ideally suited for small job, sign, and automotive shops requiring versatility along with flexibility found only with waterjet cutting. The NEOLine 40i features a new, low profile cabinetry design for easy access to pump control and components. At a 55,000 PSI operating pressure, shops are able to cut steel, glass, plastic, aluminum, stone, and much more.
The other option is KMT’s NEOLine™ 10d Direct-Drive Pump, rated at 10hp and 40,000 PSI. This direct-drive pump is specifically designed as a low-cost solution for light duty cutting and limited applications. Available in a single-phase electrical configuration, the direct-drive pump is ideally suited for small shops without three-phase power.
LinkBack URL
About LinkBacks
