auto tool change woodworking cnc router machine MT-C25H is an vertical type auto tool changing machine.It with 8 tools change system,Italy HSD 9.0KW spindle,Japan Yasukawa servo motor,LNC control system,vacuum table and dust collector.It can be used for most complex works.
Main Parameters:
NO. Description Parameter
1 Table size 1300×2500mm
2 X,Y working area 1300×2500mm
3 Z working area 200mm
4 Processing precision 0.02mm
5 Reposition precision 0.05mm
6 Table structure Vacuum table
7 X,Y,Z structure Z ballscrew X,Y gearwheel
8 Self-consuming power 4000W
9 Max ilding speed 50000mm/min
10 Max working speed 2500m/min
11 Spindle power HSD italy 9.0KW air cooling
13 Working voltage AC380V/50Hz
14 Spindle rotating speed 0-18000rpm/min
15 Drive Motor JAPAN SERVO MOTOR
16 Operation system TAI WAN LNC
17 Net weight 2000kg
18 Gross weight 2300kg
For more technical details and information,please freely contact Mr Jack Song from China MORN company,I am sure you will receive warm service and good machine.Email/MSN:mornh@morntech.com Skype:hmorntech
