Model: DCE
Way of fixing material: Vacuum absorbing
Driving material: Import synchronous belt
Cut materials: Cardboard, plastic board, foam board, kraft paper, fibre , PVC, PP, PS, leather, film,electronic material, composite material, etc.
Cutting way: Drawing by pen, half cutting, whole cutting
Cutting thickness: 0.5-2mm
Cutting precision: ≤0.1mm
Overlapping precision: ≤0.1mm
Resolution ratio: 0.025mm
Max speed: 1000mm/s
Working time and character: Continuous work, operating CNC and cutting at the same time, linear high-speed transmission for data.
Transmitting port International standards, parallel port/RSC232 serial port
Capacity of buffer area: Buffer area of large capacity, it can finish high-speed transmission for data at a time.
Instruction set International standards: HP-GL or DM-PL from can be selected, it is compatible with all kinds of CAD software.
Numerical control board LCD, all-English operating menu, contact button
Pen type: General signing pen, oil pen, ball pen
Main structure: Cutting platform, head, driving system, control cabinet, control micro computer, frame, vacuum pump
Voltage: AC 220vą10% 50Hz
Fuse standard : 5A
LinkBack URL
About LinkBacks
