K45MT-S Series
Technical Parameter:
Model K45MT-S
X-Y-Z axis working area 1,300 x 2,500 x 200mm
Machine size 2,150 x 3,150mm
Resolutions 0.025mm
X-Y movement Rack and pinion, gear drive/Taiwan
Z movement Ball screw drive/Germany
Guide Linear ¢20 square/Taiwan
Max. speed 35,000mm/min
Max. cutting speed 25,000mm/min
Spindle 1 4.5 kw/(wind cooling)
Spindle 1 speed 18,000rpm
Inverter 1 power 7.5kw
Spindle 2 6 kw/wind cooling (can use in 90 degree)
Spindle 2 speed 18,000rpm
Inverter 2 power 11kw
Drive motors stepper
Working voltage AC380V/50-60Hz, 3-phase
Command code G code
Computer interface USB 2.2
Collet ER25-12.7mm,6mm,3.175mm
Software Type3 Software/France
Controls DSP0501 For Two Spindle
Packing dimensions 2260 x 3100 x 1960 mm,1450 kgs
Equipment included
A. Oil lubrication system
B. Auto adjusting device
Equipment available
A. Vacuum system
B. Dust collector
Please feel free to contact me.
Any question will be much appreciated.
Thanks.
--Bella
