Results 1 to 2 of 2
Thread: multi-spindles cnc router model K45mt-DY
    Nov 2011
    China
    Thumbs up multi-spindles cnc router model K45mt-DY
    K45MT-DY Series
    Technical Parameter:
    Model K45MT-DY
    X-Y-Z axis working area 1,300 x 2,500 x 200mm
    Machine size 2,150 x 3,150mm
    Resolutions 0.025mm
    X-Y movement Rack and pinion, gear drive/Taiwan
    Z movement Ball screw drive/Germany
    Guide Linear ¢20 square/Taiwan
    Max. speed 35,000mm/min
    Max. cutting speed 25,000mm/min
    Spindle 1 4.5 kw/wind cooling
    Spindle 1 speed 18,000rpm
    Inverter 1 power 7.5kw
    Spindle 2 4.5 kw/wind cooling
    Spindle 2 speed 18,000rpm
    Inverter 2 power 7.5kw
    Spindle 3 4.5 kw/wind cooling
    Spindle 3 speed 18,000rpm
    Inverter 3 power 7.5kw
    Drive motors stepper
    Working voltage AC380V/50-60Hz, 3-phase
    Command code G code
    Computer interface USB 2.2
    Collet ER25-12.7mm,6mm,3.175mm
    Software Type3 Software/France
    Controls DSP0501 For Three Spindles
    Packing dimensions 2260 x 3100 x 1960 mm,1450 kgs
    Equipment available a.Vacuum system
    b.Dust collector
    Attached Thumbnails Attached Thumbnails multi-spindles cnc router model K45mt-DY-k45mt-d3_.jpg   multi-spindles cnc router model K45mt-DY-.jpg   multi-spindles cnc router model K45mt-DY-.jpg   multi-spindles cnc router model K45mt-DY-.jpg
    Nov 2011
    China
    This is an asynchronous working model, we can also add more spindles.
    any comment? ^_^
  1. new product- cnc woodworking machine model K45mt-3
    By bellawyl in forum Product and Manufacturer Announcements
    Last Post: 11-15-2011, 12:45 AM
  2. Suggestions on Multi-purpase CNC router??
    By JohnnyVegas in forum CNC Tooling
    Last Post: 09-28-2009, 08:31 PM
  3. Multi Cam MG series cnc router error codes
    By japco43 in forum Commercial CNC Wood Routers
    Last Post: 10-06-2007, 10:32 AM
  4. Replies: 5
    Last Post: 09-27-2007, 10:01 AM
  5. 1995 Multi-cam model 48 info
    By 1enick72 in forum Commercial CNC Wood Routers
    Last Post: 01-29-2007, 11:36 PM
