Results 1 to 2 of 2
Thread: new product- cnc woodworking machine model K45mt-3
    Nov 2011
    China
    Thumbs up new product- cnc woodworking machine model K45mt-3
    K45MT-3 Series
    Technical Parameter:
    Model K45MT-3
    X-Y-Z axis working area 1,300 x 2,500 x 200mm
    Machine size 2,150 x 3,150mm
    Resolutions 0.025mm
    X-Y movement Rack and pinion, gear drive/Taiwan
    Z movement Ball screw drive/Germany
    Guide Linear ¢20 square/Taiwan
    Max. speed 35,000mm/min
    Max. cutting speed 25,000mm/min
    Spindle 1 4.5 kw/wind cooling
    Spindle 1 speed 18,000rpm
    Inverter 1 power 7.5kw
    Spindle 2 4.5 kw/wind cooling
    Spindle 2 speed 18,000rpm
    Inverter 2 power 7.5kw
    Spindle 3 4.5 kw/wind cooling (can use in 90 degree)
    Spindle 3 speed 18,000rpm
    Inverter 3 power 7.5kw
    Drive motors stepper
    Working voltage AC380V/50-60Hz, 3-phase
    Command code G code
    Computer interface USB 2.2
    Collet ER25-12.7mm,6mm,3.175mm
    Software Type3 Software/France
    Controls SYNTEC EMBED_CNC Control System
    Packing dimensions 2260 x 3100 x 1960 mm,1450 kgs
    Equipment available a.Vacuum system
    b.Dust collector
    Attached Thumbnails Attached Thumbnails new product- cnc woodworking machine model K45mt-3-k45-3.jpg   new product- cnc woodworking machine model K45mt-3-.jpg   new product- cnc woodworking machine model K45mt-3-.jpg   new product- cnc woodworking machine model K45mt-3-.jpg
    Nov 2011
    China
    This is an multi-spindles model, the spindle in the middle can work in 90 degree.
    any comment? ^_^
  1. Replies: 0
    Last Post: 10-04-2011, 08:00 PM
  2. Replies: 0
    Last Post: 08-01-2011, 10:40 PM
  3. saleCNC laser engraving machine and CNC woodworking machine
    By zhangrui1588 in forum General Laser Engraving & Cutting Machine Discussion
    Last Post: 05-08-2011, 04:54 PM
  4. sell CNC Woodworking Machine,CNC Advertising Machine
    By zhangrui1588 in forum Product and Manufacturer Announcements
    Last Post: 05-30-2008, 09:43 AM
  5. Trying to come up with a woodworking machine lift
    By LewisCobb in forum Mechanical Calculations/Engineering Design
    Last Post: 05-03-2008, 02:17 PM
