Jet Edge will demonstrate its 90,000 psi waterjet cutting technology at FABTECH, Nov. 14-17 in Chicago. Look for Jet Edge in booth 2739.
During FABTECH, Jet Edge will showcase several innovative precision waterjet cutting products, including its 90,000 psi (6,200 bar) X-Stream waterjet intensifier pumps and Mid Rail Gantry precision water jet cutting machine. Jet Edge technical experts will be available to answer questions about waterjet cutting applications.
Jet Edge Mid Rail Gantry Waterjet System
Capable of producing complex parts out of virtually any material, the Jet Edge Mid Rail Gantry waterjet cutting machine features an exposed tank that easily accommodates overhead loading. It comes standard with one abrasivejet cutting head; a second cutting head can be added to increase productivity. Optional mirroring capabilities make it possible to cut part cycle time in half.
The Mid Rail Gantry is ball-screw driven for higher accuracy. Its sturdy heavy-wall tubular steel construction eliminates vibration and increases longevity. The Mid Rail Gantry utilizes an industrial PC controller and can be configured so that all three axes are fully programmable (Z optional). It also features direct-couple AC brushless digital servo motors and single or double carriages. Critical bearing components are protected with heavy metal covers with brush seals and positive air pressure. The Jet Edge Mid Rail Gantry waterjet machine is available in many sizes, including 5’x5’, 5’x13’, 8’x5’, 8’X13’, 13’x13’, 21’x5’, 21’X13’ and 24’x13’.
X-Stream Waterjet Intensifier Pumps
Jet Edge will exhibit its 100hp, 90KSI X-Stream xP90-100 waterjet intensifier pump. Jet Edge’s X-Stream pumps are capable of producing 90,000 psi and support 75,000 psi continuous operating pressure. The X-Stream achieves much faster cutting speeds and drastically lowers operating costs compared to traditional 60KSI water jet pumps, enabling users to increase productivity and reduce part costs.
The X-Stream produces 50% more pressure than a 60,000 psi intensifier pump, resulting in a 40-50% increase in productivity for many materials. Compared to a 60,000 psi pump, typical operating pressures of 75,000 psi use 30% less water, 30% less power, and up to 50% less abrasive, resulting in a 40% reduction in operating costs. The xP90-100 is capable of producing flow rates of 1.45gpm and supports up to a .017” orifice. Fittings and tubing are rated for 100KSI. The X-Stream is backed by nearly 10 years of extensive research and development in hyper-pressure technology. The X-Stream is also available in a 50hp model.
About Jet Edge
Established in 1984, Jet Edge is a global designer and manufacturer of waterjet systems for precision cutting, surface preparation and coating removal. Jet Edge systems are used around the world in a broad range of industries, from the world's leading airlines to automotive, aerospace, industrial manufacturers, machine and job shops. Jet Edge waterjets are proudly made in U.S.A.
More Information
For more information about Jet Edge, visit www.jetedge.com, e-mail sales@jetedge.com or call 1-800-JET-EDGE or 763-497-8700. Follow us on Twitter @jetedge.
INFO REQUEST FORM
LinkBack URL
About LinkBacks
