300rpm / 360rpm support for 1.2Mb floppies has been added.
Tested succesfully on strange TAJIMA / ZSK / BARUDAN.
EMUFDD 4.0 - USB Floppy Disk Replacement / Hardware Emulator
* comes to you with all supported floppy interfaces within an unique firmware, jumper-free configurable
* loads data directly from USB-key standard DOS directories
* is the only emulator that loads/saves data also in ISO standard format, readable by every virtual floppy software and floppy low level editor
* can emulate system floppies, particular floppies that can't be simply copied but need a clone operation
* can emulate any non-standard floppy format (640Kb/800Kb/1.28Mb/...)
* EMUFDD + Virtual Floppy Drive (VFD) is a complete data exchange system, more than a plain floppy emulator
* is an original product, designed & assembled in Italy since 2009
EMUFDD lets:
* any computer and industrial machinery go on working, without hardware or software change
* people just switch off, replace the old drive and turn on: complete stand-alone hardware emulation
* people go on working, avoiding or deferring expensive machinery replacement
* load data into the internal memory & plug the USB-key off : no need to keep the USB-key always plugged in
* customers rely on a prompt and effective technical support - direct line with the designer
Universal support for custom rotation speed and
custtom data density (FM, MFM, 125KHz - 500KHz)
has been added.
Product manual can be found here.
This looks great!
but where could I actually buy one of these things?
I don't want to break the bank, yet I could use several of these...
Frito
The EMUFDD4 tech-page is here:
(You can write directly to Eng. Cosimo's email)
The best thing about EMUFDD4 is that it's not a mass product.
You will be freely helped in collecting all the infos about
your floppy drive, your floppy disks and the host.
After that we will be able to preconfigure EMUFDD4 for your
machinery/device, with 100% read/write support.
We provide free customer assistance BEFORE purchasing,
with NO OBLIGATION to purchase. This way we get a unique
100% rate of satisfied customers.
"You ask & EMUFDD4 emulates it - Universal support within an unique emulator"
EMUFDD with USB & ETHERNET
Floppy-to-USB/ETHERNET retrofit and upgrade is now available for any existing industrial machinery:
ABB, ACIERA, ACORN, ADVANTEST, AGATHON, AGIE, ALBERTI, ALLEN-BRADLEY, ALPS, AMK, ANDRON, ANILAM, ARBURG, ARIES, ASEA, ATEK, B&R, BARUDAN, BECKHOFF, BENDIX, BIESSE ROVER, BMB, BOEHRINGER, BOSCH, BRUETSCH, BULLERI, BYSTRONIC, CARSTENS, CENTURION, CHARMILLES, CHIRON, CINCINNATI, CITIZEN, CNI, COMERIO, DAL MASCHIO, DECKEL, DELEM, DENN, DIXI, E&S, ECKELMANN, ELESTA, ELEX, EMCO-TURN, ESAB, ESA/GV, FANUC, FIDIA, GE, HAAS, HAPPY, HEIDENHAIN, HKD, HP, IBM, INTERMAC, iRMX, ISEL, ITT, JUMBERCA, KAWASAKI, KONGSBERG, KORG, KUKA, LECROY, LEIFELD, MANDELLI, MAZAK, MELDAS, MIKRON, MILLTRONICS, MITSUBISHI, MITSUMI, MORBIDELLI, MORI-SEIKI, MOTOMAN, MULTITRON, NEC, NUM, NUMERIK, OKUMA, ORLA, OSAI, PANASONIC, PFAFF, PHILIPS, PLURITEC, PROTTI, R&D, ROLAND, SAURER, SCM, SEFRAM, SELCA, SHIMA-SEIKI, SIEB&MEYER, SIEBERT, SIEMENS, SONY, STAUBLI, STUDER, TAJIMA, TEAC, TEKTRONIX, TOSHIBA, TOYODA, TOYOTA, ULTIMAX, UVA, WNT200, YAMAHA, YE-DATA, YOKOGAWA, ZINSER, ZSK
example: AGIE-CHARMILLES
example: MORBIDELLI
example: ARBURG
example: LEIFELD
Updated information on the floppy disk drives hardware interfaces and FDD enumarator to replace 3.5 inch and 8 inch floppy disk drive units. these device are not externally USB floppy disk drives.
The EMUFDD emulator is a hardware floppy disk emulator.
It works like a bridge.
One side is connected to the CNC / machinery, using the
floppy disk flat cable: 34pin, 26pin, ...
it depends on the original floppy drive !
The other side is the front panel, where you can
- [USB] plug in standard USB keys with no special format
- [ETHERNET] plug in the standard RJ45 connector
What does this product cost? I am interested.
USB & Network floppy retrofit/upgrade.
Worldwide selling and assistance directly from the manufacturer (Italy).
- Full customization and problem solving support before buying
- 100% working warranty
- Lifelong endurance in any harsh industrial environment
ABB, ACIERA, ACORN, ADVANTEST, AGATHON, AGIE, ALBERTI, ALLEN-BRADLEY, ALPS, AMADA, AMK, ANDRON, ANILAM, ARBURG, ARIES, ASEA, ATEK, B&R, BARUDAN, BECKHOFF, BENDIX, BIESSE ROVER, BMB, BOEHRINGER, BOSCH, BRUETSCH, BULLERI, BYSTRONIC, CARSTENS, CENTURION, CHARMILLES, CHIRON, CINCINNATI, CITIZEN, CNI, COMERIO, CYBELEC, DAL MASCHIO, DECKEL, DELEM, DENN, DIXI, E&S, ECKELMANN, ELESTA, ELEX, EMCO-TURN, ENGEL, ESAB, ESA/GV, FANUC, FIDIA, GE, HAAS, HAPPY, HEIDENHAIN, HKD, HP, HURCO, HYDRONICA, IBM, INTERMAC, iRMX, ISEL, ITT, JUMBERCA, KAWASAKI, KBA, KONGSBERG, KORG, KUKA, LECROY, LEICO, LEIFELD, LIEBHERR, MANDELLI, MARANGONI, MAZAK, MELDAS, MIKRON, MILLTRONICS, MITSUBISHI, MITSUMI, MORBIDELLI, MORI-SEIKI, MOTOMAN, MULTITRON, MULTRONICA, NEC, NUM, NUMERIK, OKUMA, ORLA, OSAI, PANASONIC, PFAFF, PHILIPS, PLURITEC, PROTTI, R&D, ROLAND, SAKURAI, SAURER, SCM, SEFRAM, SELCA, SELOGICA, SHIMA-SEIKI, SIEB&MEYER, SIEBERT, SIEMENS, SODICK, SONY, STAUBLI, STEIGER, STUDER, TAJIMA, TEAC, TECNOS, TEKTRONIX, TOSHIBA, TOYODA, TOYOTA, ULTIMAX, UVA, VAMATEX, WNT200, YAMAHA, YE-DATA, YOKOGAWA, ZINSER, ZSK...
All infos are provided writing an emailHe never just answered directly. I needed to send my machine make/model to him. I lost interest.
to the EMUFDD customer support.
Moreover the emulator is a fully
custom & integrated product,
not a mass hardware sold "as it is".
Pricing comes only after collecting exact
infos about your machinery & control.
Usually customers appreciate this professional approach.
No, you can't find any other product even similar to EMUFDD.I've also found others for around $50-$400... I believe they cost less than the EMUFDD
Obviously our focus is on
- strange/special industrial machinery
- endurance in harsh industrial environment
- CNC editing software integration and floppy virtualization
- floppy disk analysis and support for backup of existing data
If you simply need to emulate a HD floppy
on a PC or on a musical keyboard then you
can simply buy a chinese emulator at 15$.
