Results 1 to 5 of 5
Thread: Sharpecnc VMC420+4axis
    May 2010
    China
    (Dear all friends,
    Now I introduce our machine VMC420+4axis
    The machine features:
    1. System Configuration: Bao Yuan LNC520HP
    2. Tool configuration: 10 Carousel magazine
    3. High-strength cast iron, cast iron bed base piece, the column spanfor the large, inverted "Y"-type network structure, the slide box for the network structure.
    4. XYZ-axis double nut precision ball screws, precision lead screw bearings in pairs, direct-type couplings
    5. Triangle stainless steel protection, automatic centralized lubrication system
    6. Cooling system, lighting system-wide protection VMC420 small machining center specifications
    NO. Item Parameter
    1 Table Size Length (mm) × width (mm) 800×260
    2 T-slot number - Width (mm) - Pitch (mm) 5-16-50
    3 Max load (kg) 100
    4 X-axis travel (mm) 420
    5 Y axis travel (mm) 270
    6 Z axis travel (mm) 400
    7 Spindle nose to table (mm) 50-460
    8 Spindle center to column guideway surface (mm) 300
    9 Spindle Prick Hole BT30
    10 Spindle Max speed 6000/24000
    11 Main motor power (kW) 2.2
    12 positioning accuracy ((mm) 0.01/300mm
    13 Repeatability ((mm) 0.01
    14 Number of tools 10 piece
    15 Tool form Carousel
    16 tool change time 4-6″
    17 Fast moving speed X/Y/Z (m/min) 10
    18 Fast cutting feed speed (mm/min) 4000
    19 Screw parameters of X / Y (diameter mm / pitch mm) 2005
    20 Screw parameter Z (diameter mm / pitch mm) 2505
    21 Track linear guideway XY20mm/Z25mm
    22 Driver motor Servo Motor
    X、Y 1KW
    Z(with brake) 1KW
    23 Voltage 380V
    24 Air pressure 0.5Mpa
    25 Machine Dimensions 1600mmX1100mmX1900mm
    26 Machine weight 2000KG
    It has ATC 10 tools changer and the fourth axis. It has high cost performance.
    Best regards,
    Leo 09/15/2011
    Attached Thumbnails Attached Thumbnails Sharpecnc VMC420+4axis-vmc420_4axis.jpg   Sharpecnc VMC420+4axis-vmc420-front.jpg   Sharpecnc VMC420+4axis-lnc-520hc.jpg
    Nov 2011
    China
    supply cnc milling machine vmc420L vmc330L VMC550l
    We, Tengzhou City Good CNC Machine Co., Ltd. has been a professional supplier and experienced manufacturer CNC mill machine from China, We especially specialize in developing and manufacturing CNC milling machines. and we have established GOOD brands which is popular among customers both at home and abroad.
    Good CNC covers an area of 10000 square meters with independent R&D. there are 100 staffs including 10 technicians and engineers. We are dedicated to the ongoing cnc milling design solutions. to guarantee the quality, we manufacture cnc milling machines and milling machines with carefully inspected raw materials and advanced manufacturing equipments.with the integration of Taiwan and Japan technology and well trained workers, our products have achieved a good reputation and well-known performance among customers. our machines have been widely used all over the world. involved in the globalization, we are also offering OEM services to customers. we can manufacture and develop products according to clients needs. our continuous development will assure everything perfect.Providing excellent machines and offering perfect services and after-sales services.
    Products: mini CNC DIY CNC Low cost CNC Small CNC Desktop CNC Milling CNC Benctop CNC CNC Machine Machine tool CNC machining CNC milling Conventional milling Universal milling CNC machine CNC machine center,keen type machine, CNC machine, CNC Machine Tools, DIY CNC VMC Series milling machine. special machine according to clients needs
    If you have any needs, just feel free to contact us by
    eddiecnc@163.com
    Taiwan spindle
    Precise ball screw
    Taiwan linear guideway
    Automatic lubricant, coolant, lamp
    Sheet metal cover,telescopic cover
    Oct 2010
    The only issue I see with buying one of your machines here in the USA is the cost of shipping and the method in which you ship.
    Becuase you have no serious US presence and do not have a US based warehouse or service location, your sales to USA and Canada home/small business users will be extremely limited, no one wants to ship a machine back to china for warranty or repair.
    This doesn't include what happens after someone purchases one of your machines.
    First, customs clearance is not provided and you have no clearing agent in the US or Canada.
    Second, you sell FOB Shanghai or FOB China and do very little to assist in the arrangement or delivery of the machine to the customers location/destination, this is OK for a business since they probably have resources but a home buyer has no clue what is involved.
    I have examined 2 of your machines, a VMC-330L and a VMC-420, the construction is typical of china and the machines in my opinion are acceptable for light to medium duty use but anyone expecting to receive a machine that will do some serious work will be very disappointed.
    The machines you sell are all based on metric standards, here in the USA imperial is the preferred measurement system so getting a machine which has a ballscrew lead of 0.1960in per turn creates confusion when the expected 0.2000in or 0.2500in is considered normal.
    Also, the castings could use some improvements to strengthen key areas of high stress and my advice, 80,000psi or 120,000psi ductile iron would be better material, it wont cost much more, is stronger and harder and will vastly improve the quality of your frames.
    It would also be better if you offered the machines with GSK 218M panels to USA sellers, at least they would be getitng a decent panel.
    And finally, you offer all kinds of information on the machine but never offer the price, this loses you potential sales because buyers cannot compare your prices against other prices and they don't want to wait on your response to get the price from you as you attempt to try and sell them the product in your reply.
    Get your machines in the USA and your USA and Canada sales will increase tremendously, for the money your machine isn't that bad.
    May 2010
    China
    Thumbs up Sharpecnc: small cnc milling machine
    Quote Originally Posted by dwalsh62 View Post
    Now I attach some new small cnc milling machines
    Attached Thumbnails Attached Thumbnails Sharpecnc VMC420+4axis-sxk06l.jpg   Sharpecnc VMC420+4axis-sxk06l-adtech.jpg
    Attached Files Attached Files
    Oct 2010
    Quote Originally Posted by leo zhu View Post
    Once again, you ignored the issues I raised and offering this machine with Mach3 and showing a picture with a GSK/HSK/DF type panel is bad and misleading.
    The cost of a GSK 980MDa1 panel is inexpensive, roughly the same as your breakout board, computer and software solution, as a GSK Authorized USA dealer I know this for a fact, I can sell this panel for $1400.00 shipped to the customer and still make a nice profit on it.
    By using a real panel, you save money because you don't need a breakout board, computer or software and the system functions with greater stability and accuracy.
    Please provide answers to the following questions:
    1. What is the cost of this machine
    2. Is the machine available as a frame with spindle assembly (no enclosure, electronics or servo/stepper motors)
    3. Is the machine already in the USA
    4. Is warranty handled in the USA
    1. Just IN- The return of Sharpecnc
      By leo zhu in forum Product and Manufacturer Announcements
      Last Post: 10-30-2010, 05:05 AM
    2. Sharpecnc S320i
      Last Post: 05-25-2010, 09:29 AM
    3. Bad boy: Sharpecnc SXK3
      Last Post: 05-20-2010, 09:50 AM
    4. Sharpecnc is born.
      Last Post: 05-11-2010, 01:31 AM
    5. Where is Sharpecnc
      Last Post: 05-06-2010, 09:26 PM
