Hi there, I'm a noob, just wondering if it is possible to engrave granite with a waterjet cutter? What is the best way to engrave granite, let's say for a sign,
Waterjet manufacturer Jet Edge, Inc. introduces the Mid Rail Gantry Model MR513 water jet cutting machine.
Capable of processing material up to 5’x13’, the Mid Rail Gantry Model MR513 water jet cutting machine is sized especially for fabricators, machine shops and stone and tile shops. It cuts complex parts from virtually any material without creating a heat-affected zone (HAZ). The Mid Rail Gantry comes standard with one abrasivejet cutting head. A second cutting head can be added to increase productivity. Optional mirroring makes it possible to cut large parts twice as fast.
Jet Edge Mid Rail Gantry waterjet systems are available in a wide range of work envelopes, from 5’x5’ to 24’x13’. Mid Rail Gantry water jets utilize an industrial PC controller and can be configured so that all three axes are fully programmable (Z optional). They feature direct-couple AC brushless digital servo motors and single or double carriages. Critical bearing components are protected with heavy metal covers with brush seals. The Mid Rail Gantry is powered by a Jet Edge waterjet intensifier pump. Jet Edge has the widest range of waterjet pumps on the market, from 25-280hp, including 36KSI (2500 bar), 60KSI (4100 bar) and 90KSI (6200 bar) models. Electric and diesel pumps are available.
Jet Edge’s Mid Rail Gantry Waterjet System is proudly made in the U.S.A. For more information, visit JET EDGE Waterjet Systems - Water Jet Cutting Machines, Surface Preparation, e-mail sales@jetedge.com, call 1-800-JET-EDGE (538-3343) or 763-497-8700.
See the Jet Edge Mid Rail Gantry Model MR513 in action this fall at CMTS and FABTECH!
About Jet Edge
Established in 1984, Jet Edge is a global designer and manufacturer of waterjet systems for precision cutting, surface preparation and coating removal. Jet Edge systems are used around the world in a broad range of industries, from the world's leading airlines to automotive, aerospace, industrial manufacturers, machine and job shops. Jet Edge waterjet systems are proudly made in the U.S.A. For more information about Jet Edge, visit JET EDGE Waterjet Systems - Water Jet Cutting Machines, Surface Preparation, e-mail sales@jetedge.com or call 1-800-JET-EDGE (538-3343).
Find Out More!
Information Request Form
www.jetedge.com
sales@jetedge.com
763-497-8700
Jet Edge is proud to sponsor CNC Zone!
Thank you for your question. Try water only, perhaps even using an abrasive head without the abrasive on. This will give you a fatter, less coherent stream than a water only head. You may have to experiment with cutting pressure. If that doesn't work, try low pressure water ( 10-15 kpsi) with abrasive at a low setting and fast feed with no ramping. Of course, test this out on scrap material. Please post a pic so we can see how it turns out!
Our customer PIW has done some very impressive etching and milling with waterjets with their patented waterjet etching and milling process. See story about them at
JET EDGE Waterjet Systems - Waterjet Success Stories - Case Studies
If you would like to speak directly to one of our technical experts, please fill out our information request form.
We have a waterjet technology webinar Oct. 26 on the Fabricator's website. To register, visit Webcasts.
Thank you!
