Results 1 to 1 of 1
Thread: The return of Sharpecnc
    May 2010
    China
    Thumbs up The return of Sharpecnc
    Dear all,
    Sharpecnc grow up, now Sharpecnc bring here his 4 axis cnc milling machine :SXK03A+4
    Dongguan Sharpe CNC Machine Co., Ltd. - cnc mill, cnc lathe, cnc drill
    The machine can drill, mill and tap all kind of hole, cut, groove distributed on the cylinder. For example: spring collet
    Technical parameters
    Serial NO. Project item Parameter specification
    1 Table size length (mm) X width (mm) 550x160
    2 The number of T-slot - width (mm) - Pitch (mm) 3-12-42
    3 X axis travel (mm) 280
    4 Y axis travel (mm) 170
    5 Z axis travel (mm) 200
    6 Spindle nose to table (mm) 50-330
    7 Spindle center to column surface of rail (mm) 185
    8 Spindle taper Manual Tool Change Spindle R8
    9 Automatic Tool Change Spindle BT30
    10 The maximum spindle speed (rpm) 3500/6000
    11 Spindle motor power (KW) 1.1/2.2
    12 Feed motor feed motor X-axis torque (Nm) 3.5
    13 Y-axis torque (Nm) 3.5
    14 Z-axis torque (Nm) 3.5
    15 Fast speed: X / Y / Z (mm / min) 2800
    16 Cutting feed rate (mm / min) 0-1000
    17 Screw parameter X / Y / Z (diameter mm / pitch mm) 16 / 5
    18 A axis turning speed (rpm) 200
    19 A axis accuracy Zero clearance
    18 Control System MACH3
    Attached Thumbnails Attached Thumbnails The return of Sharpecnc-sxk03a_4_.jpg   The return of Sharpecnc-sxk03a_4_.jpg
  1. SXK03 Vedio by Sharpecnc
    By leo zhu in forum Product and Manufacturer Announcements
    Last Post: 05-27-2010, 08:35 PM
  2. Sharpecnc S320i
    Last Post: 05-25-2010, 09:29 AM
  3. Bad boy: Sharpecnc SXK3
    Last Post: 05-20-2010, 09:50 AM
  4. Sharpecnc is born.
    Last Post: 05-11-2010, 01:31 AM
  5. Where is Sharpecnc
    Last Post: 05-06-2010, 09:26 PM
