Probe Pilot is a powerful, easy to learn, affordable, CAM based programming system for machine tool probing. Featured based point & click selection allows you to quickly create complex probe programs that can be used for part setup, probe calibration, process control, unattended machining, coordinate rotation, machine health check, as well as part inspection with formatted inspection results.. Use of macro based programming gives real time data that is available immediately at the time of measurement. Extensive measure operations that include points, bores, bosses, webs, pockets, partial arcs, internal corners, and external corners, with options such as regular tolerance, true position tolerance and variable search distance. Custom macros can be created and implemented effortlessly, including the ability to create a variable input form on the fly. Complete probe simulation for probe tool path verification. With Probe Pilot, programming your probe has never been easier.
www.ProbePilot.com
Advanced Probe Technologies, LLC
