Results 1 to 3 of 3
Thread: Kress 1050 FME-1 Now In Stock
    Jun 2005
    England
    Kress 1050 FME-1 - Available Now!
    Technical Data
    Nominal rated input - 1.050 Watt
    No-load speed - 5.000 – 25.000 1/min.
    Collet - 8mm
    Clamping collar - Ø 43 mm
    Tool weight - 1,7 kg
    Product features
    * Soft start-up and start current limitation
    * Armoured motor winding to protect against dust and particles
    * Steel motor flange with double bearing for improved milling performance
    * Electronic overload protection prevents the motor from overheating
    * Carbon cut-off brushes for motor protection
    * Suitable for driving flexible shafts
    * 4 m rubber mains cable with patented quick-lock system
    * 4 m and 6 m cables can be delivered as accessories
    Noise/Vibration Information
    Vibration strength - 5.0m/s2
    Element of uncertainty K1 - 1.5m/s2
    Noise pressure level - 78dB(A)
    Element of uncertainty K1 - 3.0dB(A)
    Sound power level - 89dB(A)
    Element of uncertainty K2 - 3.0dB(A)
    Measurement values determined according to EN 60745.
    Vibration total values (vector sum of three directions)
    Technical Data
    Registered rnr107's Avatar
    Feb 2010
    uk
    Would this spindle suitable to machine aluminium ?
    Ta,
    RNR
    Dec 2003
    Verona,KY
    details...
    How about 110v with USA plug, and 1/8" & 1/4 collet&nut instead of the metric one + spare brushes shipped to 40192 usa zip code? - I typically cut 3-4mm deep with a 3.175mm cutter, but my mill is too slow. I presume this should be up to that sort of load?
  1. How to replace Kress 1050 FME ballbearing?
    By bebson in forum CNC Tooling
    Last Post: 09-07-2009, 03:16 PM
  2. Need Help!- Kress 1050 and ER16 collets
    By K.J.Everest@blu in forum CNC Wood Router Project Log
    Last Post: 07-24-2008, 07:13 AM
  3. kress router
    By brianna187 in forum Want To Buy...Need help!
    Last Post: 04-28-2008, 11:23 AM
  4. Ge 1050 -need help
    By JR1050 in forum Machine Problems, Solutions , Wireless DNC, serial port
    Last Post: 02-24-2007, 08:14 PM
  5. head stock and tail stock chucks
    By mocnc in forum DIY CNC Router Table Machines
    Last Post: 10-19-2004, 10:16 PM
