Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > Product Announcements & Manufacturer News
Product Announcements & Manufacturer News If you are a manufacturer or company with relevant news related to machining or have a new product announcement you may post it here only! (Commercial Posting Forum)
Old 11-15-2009, 09:53 PM
fullspeceng is on a distinguished road
get rid of Newlydraw, new Mach3 Controlled 40W/50W/60W CO2 Laser Cutters and upgrades
Tired of cleaning up chips, running coolant, breaking tools, and clamping work?
Frustrated with cheap Chinese Lasers and proprietary laser cutting software?
Check out our new Mach3 Controlled 40-60W CO2 Laser Cutters:
http://www.fullspectrumengineering.com/co2laser.html
New videos:
Basic Specs:
Control board and Software designed in USA
40W/50W and 60W tube options
12.5"x8.5" cutting area
Full PWM laser control through Spindle
Low cost Kit form
Adjustable focus High end ZnSe lens
Spring loaded gold coated mirrors
High end Air Assit
Mach3 XML configuration supplied
LazyCAM post file supplied (different power/speed settings for each layer)
Export files from Adobe Illustrator/CorelDraw/Autocad
Just plug it in and cut away (sorry no chips to clean up - laser
vaporizes material)
Upgrade cards available for other NewlyDraw type laser cutters also available.
As easy as it gets.
_______________________________
low cost Mach3 controlled CO2 laser cutters, Inkjet PCB kits, Laser 3D Scanning, Solidworks 3D Mechancial Design, Electrical Engineering Design, overseas CNC manufacturing consulting
ITOP--CNC ROUTERS, LASER ENGRAVERS, LASER CUTTING MACHINES, CNC PLASMA CUTTERS oliver9866 Product Announcements & Manufacturer News 0 10-17-2008 11:17 AM
about chinese laser cutters buddhafragt Laser Engraving & Cutting Machines 11 08-04-2008 06:00 AM
MAXNC 10 controlled by Mach3: Two problems MachFlowMike General CNC (Mill and Lathe) Control Software (NC) 5 12-12-2007 04:41 PM
cnc controlled mandrel bender controlled by mach3 timmyb199 Bending, Forging,Extrusion... 5 05-30-2007 07:35 PM
Fabric laser cutters mdiaconu Laser Engraving & Cutting Machines 0 12-18-2006 03:03 AM
