Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > Product Announcements & Manufacturer News
Product Announcements & Manufacturer News If you are a manufacturer or company with relevant news related to machining or have a new product announcement you may post it here only! (Commercial Posting Forum)
Old 10-23-2009, 03:16 AM
Kung fu panda's Avatar
Kung fu panda is on a distinguished road
Smile 0 ~ 10V analog adjust speed in CNC machine
DC Brushless Motor Drive Controller Unit(CNC Machine, Mechanical Equipment)
Main function:
◆ Start, Stop, accelerate or decelerating, forward and reverse function
◆ A LCD displays real-time speed, the current state, protection
◆ A flow, over-voltage, overload, voltage protection function
◆ Motor temperature detection
◆ 0-10V analog speed control◆ Provide the user interface should choose function. Panel
◆Should provide 485 interface and TTL interface, which can be conveniently and communication
◆With a sudden stop machine, electric switch, protective mask open doors limit protection
◆Speed 400~6000rpm
◆Drivers can access AC110V/220V two kinds of voltage, in the same drive can be switched
CN17—0V ~ 10V analog speed control port when the user interface when selecting a foreign force, in this port by adding the signal voltage of 0V to 10V can realize a linear motor speed control function.
www.sangmutan.com
info@sangmutan.com
ID:	91743   Click image for larger version
ID:	91744   Click image for larger version
ID:	91745   Click image for larger version
File Type: pdf BRUSHLESS MOTOR AND CONTROLLER(110V220V).pdf‎ (496.3 KB, 50 views)
Old 10-30-2009, 02:38 AM
aiven.xie is on a distinguished road
Main function:
◆Speed 400~6000rpm
www.sangmutan.com
info@sangmutan.com
how much 1.1kw 6000rpm motor &controller ?
analog of surface speed Zig LinuxCNC (formerly EMC2) 0 09-11-2009 11:50 PM
Feed and speed to machine HSS zaebis General Metalwork Discussion 10 08-29-2009 08:35 PM
Newbie- how to adjust speed of the transmission scampo77 Benchtop Machines 11 02-07-2009 11:27 PM
analog input VFD speed Hitachi SJ100 Karl_T Phase Converters and VFD 10 11-22-2008 04:09 PM
Speed of CNC machine tivoidethuong Mechanical Calculations/Engineering Design 11 04-25-2006 06:02 AM
