Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > Product Announcements & Manufacturer News
Product Announcements & Manufacturer News If you are a manufacturer or company with relevant news related to machining or have a new product announcement you may post it here only! (Commercial Posting Forum)
Old 09-07-2009, 09:48 AM
Motiondrives is on a distinguished road
CNC Pendant Controller Kit- LOW COST
Why permanently connect your PC to your CNC machine when you can use our NEW Pendant CNC Controller?
The MO-CON501 CNC Pendant Controller with built-in DSP (digital signal processor) reads G-code, PLT files (supports most Fanuc post processing) from a USB memory stick or its internal memory. The controller then converts it into an output signal to the motor drives. It also provides digital outputs to control a spindle motor (up to 16 speeds).
The MO-CON501 also accepts inputs from up to 3 limit switches and can supply power to 3 proximity sensors. It also has an input to allow automatic setting of the Z-axis (after tool changes).
Our NEW MO-CON501 CNC Pendant Controller Kit includes:
* 1x MO-CON501 Pendant Controller
* 1x Connecting Board
* 1x SCSI cable
* 1x USB cable
* 1x 1GB memory stick
Main features
* All of the parameters are easy to set and backup to a PC
* Easy problem solving due to "On screen help function"
* Remember size of table (no need for 2 limit switches on each axis)
* Move manually in any direction at any speed
* Move to a specified position e.g. X + 20.37
* Move in user defined steps e.g. 0.1 at a time
* Remember up to 10 origin points
* Run CNC programs from a memory stick or internal memory
* Resume program from power cut or broken tool
* Check CNC program before running and report errors
* Run from any line in a CNC program to any line
* Run a CNC program in an array e.g. 3 times 100 mm apart
* Set speeds and feeds at start and change on the fly
* Turn spindle on and off automatically when program starts and finishes
* Control speed of spindle e.g. 6000rpm to 24000 in 3000 increments
* Automatically compensate for back lash if ball screw is worn e.g. 0.005 in X
* Machine a user defined area without a program e.g. 25mm by 80mm 2mm deep in 0.5 cuts
All manuals, wiring diagrams, videos, and windows transfer software for the MO-CON501 CNC Pendant Controller Kit are supplied on the Memory Stick.
Online technical support and remote desktop assistance are available. Please contact Motion Control Products Ltd for more details or go to following link with discount for multiple purchase.
http://www.motioncontrolproducts.co....php?cPath=1008
email: enquiries@motioncontrolproducts.com Tel.: 0044 (0)1202 599922
Old 09-09-2009, 03:50 AM
draughted's Avatar
draughted is on a distinguished road
if its an affordable item i'd use it.
looks just right for a plasma i'm planning!
Old 09-09-2009, 08:37 AM
Talking
Hi there,
You can go to the following link below to check the details:
discount available for quantity purchases .
P.S. we got your email and will send you the manual if you require.
Regards
Old 09-09-2009, 05:55 PM
Greolt is on a distinguished road
This looks very much like the controller I have seen and used on the Chinese import CNC routers.
Is it the same? Don't remember the Chinese ones having spindle speed control.
Greg
Old 09-10-2009, 09:50 AM
Hello Greg,
Many thanks for your reply, yes you are correct, we are working with our factory and have improved this products with them.
We are now launching the new version without all the Chinese with a full English version manual, easy guide, example programs, connection guide and full on line software support on the web.
This will be easier to work with, etc.
I would like your feedback on working with the old version on the CNC machines.
Thanks.
The MCP Sales Team.
Greg
Old 03-17-2010, 03:24 PM
ironman014's Avatar
ironman014 is on a distinguished road
I recently started a new job where they bought a chinese router. someone built (in house) a controller board so we can run 'Mach3'. I want to now learn how to use the original controller, it's looks just like the pendant controller MO-CON501 ( http://www.cnczone.com/modules.php?n...&postid=663613 ) the old controller board is gone and i don't have a cable,mem card or usb. Any ideas or help would be appreciated. Motiondrives say they have a manual i wonder if i had that i could figure out a shopping list.
thanks in advance for any help.
Mike S.
CNC guy at LVI group West BAnk B.C.
mikescottishere@gmail.com
Tags
cnc control, controller, fanuc, g-code, pendant
New low cost CNC Controller, USB, Windows XP based! bert_eding Product Announcements & Manufacturer News 13 10-25-2009 03:14 PM
New help Pendant vs Game Controller Hack for Taig gunlocators Taig Mills & Lathes 5 10-31-2008 01:40 PM
diy cnc controller? pendant? bp092 DIY-CNC Router Table Machines 2 10-30-2007 05:18 AM
Jog Pendant or Shuttle Controller? keen Tormach PCNC 18 09-04-2007 09:47 AM
