| Product Announcements & Manufacturer News If you are a manufacturer or company with relevant news related to machining or have a new product announcement you may post it here only! (Commercial Posting Forum) |
#13
| this is detail specifications about our brushless motor and control use in mini-machine,you can just buy 3 or 4 motors,or even 2,this is no problem, motor power: 1100W 3500RPM OR 6000RPM DC300v 1500w 3500RPM OR 6000RPM DC300V controller:Input AC110V or AC220V Should you have any questions, please do not hesitate to contact me E-mail:info@sangmutan.com web: www.sangmutan.com |
#17
| yes we have workers rights, We are producers, not traders all the accessories used in our motor and controler are environmental materials on the "cnczone.com" many milling and drilling machine company are use our brushless and controller as their spindle motor |
#18
| Today, I will lead brushless spindle motor and drive detailed information on here, Welcome everyone come to know more about them |
#19
| could you give your e-mail to me, so I can send you a detailed description or you can send a E-mail to me ,my E-mail :info@sangmutan.com |
#20
#22
| SPECIFICATION Brushless DC Motor and Driver for Small CNC Milling and Drilling Machine Product Overview: Power : 1100W ,1500W ,2200W Speed Range : 200rpm-10000rpm Features :This series of Brushless DC Motor Drive Unit is designed as specific systems for some small milling machine. This control system with perfect function, simple operation, capability of anti-interference, energy saving, low breakdown rate and easy maintenance which can achieve maximum torque and smoothness when at low speed. The whole system include brushless DC Motor (92BLM-GM-300HA,123BLM-IN-300HA) and brushless DC motor driver(BLMC-1100-300H, BLMC-2200-300HA), Function Board(SMT-1100), SMT-LCD , as shown in Figure F1-1. Before the installation, Please choose the brushless DC motor with voltage, power and speed of the corresponding driver. Application : Lathe , Milling Machine ,Drilling Machine Market: Demanding of Machine Tools in domestic and abroad is higher day by day , Brushless motors has become the mainstream driving device in the European and American market as its stable performance, low noise, no electromagnetic interference Please read safety warning below carefully before Installing and operating this controller 1、This product should be installed and serviced by a qualified technician , electrician ,or electrical maintenance person familiar with its operation and the hazards involved 2、Insulated adjustment tools must be used when working under power .Do not touch the PCB board and junctions when working under power 3、All output and input terminals are NOT isolated from the incoming supply Type Model: Brushless motor Power 92ET-BLM-300HA-SMT AC220V/110V 500W 3500RPM、6000RPM 92ET-BLM-300HA-SMT AC220V/110V 750W 6000RPM、12000RPM 92GM-BLM-300HA-SMT AC220V/110V 1100W 3500RPM, 6000RPM 123HM-BLM-300HA-SMT AC220V/110V 1500W 3000RPM, 6000RPM 123IN-BLM-300HA-SMT AC220V/110V 2000W 4000RPM, 6000RPM 123IN-BLM-300HA-SMT AC220V/110V 2200W 3500RPM, 6000RPM Remarks: Various parameters of the above are present in accordance with our customer's specific technical requirements for customer development, such as the above parameters do not meet your requirements, we can independently developed specifically brushless motor and controller system for your products suitable for your Main function: ◆ start, stop, accelerate or decelerating, forward and reverse function ◆A LCD displays real-time speed, the current state, protection A flow, over-voltage, overload, voltage protection function ◆ Provide the user interface should choose function. Panel ◆Should provide 485 interface and TTL interface, which can be conveniently and communication ◆With a sudden stop machine, electric switch, protective mask open doors limit protection 一、brushless DC motor driver features ◆ AC220V power supply for ◆ Rated power 2200W, rated current of 12A, maximum current of 18A ◆ rated speed to 6000RPM, speed range of 400-6000RPM, acceleration time 5S. ◆ PID closed-loop speed and current dual-loop regulator, speed-loop control accuracy of ± 1% ◆ has a limited flow, start-up failed, blocking switch, the module protection ◆ have the machine stop switch, protective masks, opening the door electronically controlled limit protection ◆ LCD display with the actual speed machine tool spindle and the work of the drive, and speed showed an accuracy of ± 2% ◆ regulating the use of key board drives the work of the state, operation is simple and convenient ◆ outside the user interface used to control the work of the drive, and easy to implement digital control of the working drive. Second, DC brushless motor drive unit on 2.1 Brushless DC Motor Driver Motor drive can control the start, stop, acceleration, deceleration, forward , reverse, tapping, current limiting protection, stop, open doors electronically controlled power-off protection and turn off the protection of protective masks, it can be outside the user interface control. Overload protection: motor load of more than 1.5 times the rated load immediately 30S downtime, protect the code at the same time show that E5. 2.2 key board Key board through the function keys to control the operational status of the drive. Key point in the effective action will be issued a "drip" sound, a long time and even made the "drip, drip" sound, made null and void only a "drop" would not be able to voice. The key features are as follows: 1. START Starter drive control button 2. STOP control button to stop the drive 3. FORWARD drive control keys are running 4. REVERSE drive reverse run control button 5. "+" To accelerate the drive control keys 6. "-" Keys to Deceleration the drive speed 7. TAPPING Tapping drive control function 8. Tapping features LED light-emitting diodes instructions 9. Protective masks CON3 interface switch, short-circuit To enter the stop state, all button does not work, disconnect By start-up device according to the system before the resumption of short-circuit state. Function of the terminal block CN1- U, V, W, respectively, then the U-phase motor, V-phase, W phase; FG then the earth, N then zero line, L line of fire then. CN2-Hall sensor, respectively, from the electrical terminals of the Hall sensor line S1 of the K1, K2 can be used for the threshold switch, stop switch, such as the protective effect, as long as the K1, K2 short circuit, the controller immediately stop working. CN10—485 Serial communication port Can be easily prepared with the realization of other high-line, so that intelligent controller, to facilitate better operation of more simple CN11—Ordinary TTL serial port CN12-speed signal output can be used to detect the motor speed, a pulse for 1RPM CN13-error signal output when there is under-voltage, over-current, stall, start-up failure, the output high CN14-serial / external user interface to choose the port when the port open, use serial communication to achieve control of the controller, when the port short-circuit, serial failure, CN15 effect. CN15—Outside the user interface control port when the short-circuit CN14, launching the user control signal ① External +12 V power supply ② External +5 V power supply ③Tapping external low-level functions, the tapping function of effective motor to 1000RPM / m; high power or open invalid ④Start / stop in the shutdown state to a negative pulse start, turned down in a negative pulse stopped, a negative pulse every time a status change ⑤Positive / negative inversion pulse every time a status change ⑥PWM control input-pin 500-5KHz of the PWM control signal 10% - 90% of the minimum speed can be controlled to the highest (Recommended frequency: 1KHz) ⑦External power supply ground 三、Key board 1.System in accordance with the wiring diagram to connect after a good line, or if the SA at this time SQ1, SB1 are closed to disconnect SQ2. The buzzer sounded a "drop", LCD display "0000, FOR, STOP", key board "FORWARD, REVERST, TAPPING, START" keys are valid, machine tool spindle and the spindle motor speed ratio of 1:1, indicating Speed is a motor speed of 1:1. 2. Press "START" key to switch the drive motor is displayed is the lowest speed to 400RPM ± 10% runs, start-up time. For the most high-speed motor 6000RPM ± 1%. 3.Every move the "+" allows a driver to increase motor speed 20RPM, long press "+" key to drive fast so that motor speed to 6000RPM. Every time "-" button allows drive motor speed decreased when the rules and to accelerate the contrary. 4."FORWARD" for the motor drive control keys are run. "REVERST" motor-driven reverse run control button. Switching the direction of each motor deceleration to 1000 before the first switch, switch automatically after the completion of the restoration to the original speed of the speed. 5."TAPPING" for tapping keys with non-tap switch. Every time a state switch. Tapping into the light when the LED diode. 1000-6000RPM when tapping the state can directly switch to the non-tapping, and tapping the state of non-state switch to tapping speed switch automatically dropped from 1000RPM to keep upon completion, the drive will speed 1000-6000RPM add to switch positive / negative when , allows drive motor speed can be automatically dropped from 1000RPM to accelerate the switch to after the completion of 1000RPM rotational speed and maintain. Tapping keys on the board when the "FORWARD, REVERST" invalid, use the CN2 terminal on the drive external button switch S2 is / reverse, each point is a movement to switch / reverse. 6.Drive in any state by the "STOP" to enter the stop state, and the current state of memory, when the key board "FORWARD, REVERST, START" effective ,"+,-, TAPPING "null and void. The next by the "START" button to stop the automatic recovery when the rotational speed before. 7.Overload protection: motor load of more than 1.5 times the rated load down immediately 30S, also showed protection code E5 8、Drive in any state as long as the work of "SQ1, SB1" one disconnect switch, drive off immediately. At the same time, work lost state drive. 9、Key board drives the four positioning holes to be fixed with the lathe cutting insulation to increase the insulation strength of tablets. Button plate and fixed parts lathe preferred plastic material. Welcome to contact us directly, we will have a professional technical staff to answer your questions, Thank you choose our company's products. ShenZhen Sangmutan Motor Co.,LTD Contact Phone : +86-0755-29785329 +86-0755-29785729 Sales hot Line : +86-0755-29785329-138 +86-0755-29785279-188 FAX: +86-0755-29785329-128 +86-0755-29785729-128 E-mail :info@sangmutan.com 24-hour business line :13631557179 15899766518 ADD: B of 2F Building C,Yongqi Science Park,Lezhujiao Village XiXiang, Baoan, Shenzhen. |
| make a brushless servo use pic or avr for cnc controller,let's go! | xosliu | CNCzone Club House | 3 | 09-20-2010 09:08 AM |
| HappyServo - Open Source Brushless Servo Controller | DerekZahn | Open Source Controller Boards | 27 | 07-30-2010 09:06 AM |
| Bldc motor and controller is used in the mini machine | wang | Product Announcements & Manufacturer News | 53 | 09-19-2009 07:05 AM |
| Stepper Motor Controller For A 3 Axis CNC Machine | mattn | Stepper Motors and Drives | 3 | 02-09-2007 02:50 PM |
| I'm looking for a simple speed controller for a brushless AC motor. | trilect | General Electronics Discussion | 4 | 05-11-2005 08:45 PM |
