Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > Product Announcements & Manufacturer News
Product Announcements & Manufacturer News If you are a manufacturer or company with relevant news related to machining or have a new product announcement you may post it here only! (Commercial Posting Forum)
Old 09-06-2009, 02:21 PM
Ryan P's Avatar
Ryan P is on a distinguished road
Nesting Program
Introducing a new nesting application with dxf output. Nester uses VB scripts to produce the dxf drawings these scripts are able to be edited by you to produce parametric nested dxf drawings. Included scripts will produce dxf files outlining the parts and one for creating a dxf file for MDF doors.
There are functions in the scripting to create text, circles, three point arcs and rectangles.
With the power of VB scripting one could write a script to output G code.
A trial version can be downloaded at http://www.cabinetpartspro.com/Nester/Nester.htm
If you have any questions or suggestions Please email me at www.cabinetpartspro.com
Ryan
Old 09-07-2009, 07:49 AM
cabnet636 is on a distinguished road
it works perfect will post video soon!!
jim
James McGrew camaster x3, aspire software
www.mcgrewwoodwork.com
Old 09-07-2009, 09:16 AM
Dropout is on a distinguished road
Hi Jim (and Ryan).
I downloaded it and tried to nest some basic rectangles with mixed results. 24.375 by 34 worked fine but 24 by 41.75 didn't. I should have gotten three to a sheet but only got two.
For some reason it didn't want to rotate the rectangles even though the box to do so was checked off.
Maybe there is something in the settings I don't understand.
Old 09-07-2009, 11:05 AM
look at whether or not is is using the off fall or leftover from the previous sheet
jim
Old 09-07-2009, 11:19 AM
i chaned settings to nest and rotate and changed width and height and i got three 24x42 to a sheet
ryan is working on more for this
jim
Old 09-07-2009, 01:05 PM
Ryan P's Avatar
Dropout,
There is a few couple settings that could effects the nesting one is the part spacing and the other is the option for panel saws. You will also want to check as Jim Pointed out, it is not using a waste material. Usable waste will be added to the material let and will be used before any full sheets. If you do not want to have waste added change the waste settings. Making the area, longer or wider bigger than the full sheets will prevent the waste from being added. For example your main material is 96 X 48 making the Keep Longer setting 98 to waste will be added to the material list.
I hope this helps please let me know if I need to explain in more detail.
Ryan
info@cabinetpartspro.com
Old 01-01-2011, 02:09 PM
Ryan P's Avatar
ParaNester has an update.
The update includes a setting for edge trim and includes two new nesting options. The two added nesting options are used for those cutting on a beam or table saw.
I you have bought with-in a year and have not received new codes please send me an email.
The new version can be downloaded from this page: http://www.cabinetpartspro.com/OtherProducts.aspx
If you have any questions or need help please email me at info@cabinetpartspro.com
Auto Nesting program Need ???? BFcarbon OpenSource Software 2 09-24-2009 08:53 AM
X3 nesting foxsquirrel Mastercam 4 08-11-2008 10:03 PM
2D On-Line nesting - Nesting on-demand ! mijo Product Announcements & Manufacturer News 0 03-21-2006 09:42 AM
Nesting alnicov SheetCam 4 04-01-2005 08:41 AM
3d Nesting broncosis General CNC (Mill and Lathe) Control Software (NC) 1 03-24-2005 08:38 PM
