| Product Announcements & Manufacturer News If you are a manufacturer or company with relevant news related to machining or have a new product announcement you may post it here only! (Commercial Posting Forum) |
| I'm glad to announce the all new DualDC feature for the famous Granite Devices VSD-E/XE servo drives. What's it all about? A single VSD-E-160 or VSD-XE-160 servo drive can now control two independent brush DC servo motors (sized between 10 and 1000W, each) by means of new DualDC firmware. The DualDC firmware can be downloaded at no cost. And if necessary, the original single axis firmware can be restored to drive any moment. In other words, drive 2 axis lathe with just a single drive or control 4 axis mill with two drives. Drive is fully compatible with Mach3, EMC2 and SmoothStepper. ![]() ![]() Major benefits
Feature highlights
Easiness redefined Setup of drive has been made particularly easy. The new DCtool software takes guesswork out of tuning. Attention has been paid also to drive manual, which contains detailed usage instructions with complete wiring diagrams. ![]() Hungry for more? VSD-E/XE in DualDC mode: product page VSD-E/XE in advanced single axis mode: product page Drive comparison to competing drives (Geckodrive etc): comparison pdf For more information, feel free to contact me by PM, email or by posting to this thread! Best Regards, Tero Kontkanen |
Hay Tero, Wow you are making servo drives cost effective.I have to rethink steppers.There is too many stepper vs servo threads.I wish someone could could come up with an answer.From the posts,steppers can stall with no damage while servos are un stopable and will smoke and burn untill they reach China.I thought limit switches prevented the gantry from flying off the table.I would suppose the drive would sence a crash and current limit or sense a fault.From the servo vs stepper posts this appears to be the worry for the CNC dummies such as my self.Perhaps you could elaborate on the subject and give confidence to using servos for dummys. I don't know much of servos ratind.They usually are rated in peak oz/in.Is it better to rate in watts to find the right motor. E/G I have 6ooLb gantry wishing to move at 600IPM...Watts=IPMXlbs/531 600X600/531=671Watts.From the servo specs I would select the constant current and voltage to make my selection.Is this the correct way to select a servo? One other Question aimed at servos or steppers.I have read in posts it is best to use the same motors in each axis to avoid tuning nightmares. Larry
__________________ L GALILEO THE EPOXY SURFACE PLATE IS FLAT |
| Hi Larry, 1) I typically install servos when the risk of machine damage needs to be minimized. With servo you can set precise torque limits (by means of current limit). Torque limiting is difficult with stepper as its torque tends to very high at low RPM and reduces to almost zero at high speeds. The "encoded failure detection" feature of VSD-E also protects machine since it disables motor quickly if mechanical blocking is detected. 2) To choose a servo motor, first determine required motor mechanical output ratings (i.e. torque and RPM). You need to know 2 values out of these: torque, rpm, power. Third value can be always calculated from any of the two known values. There are various calculators and formulas to estimate the torque/power/speed demand. After motor output ratings are known, choose a motor model that fits to your drive in current & voltage rating. 3) It may be little bit easier to use same kind of motors for every axis, but it's not so complicated to use different types either. If you know how to set-up one motor, you know how to set-up them all. |
| I redesigned the contents of DualDC product page. Now its much more informative and clearer, too: http://www.granitedevices.fi/index.p...e-dualdc-servo |
| Tags |
| dc servo, servdrive, servo drive, servo motor |
| Need Help!- servo drives | Minnesota HD 10 | Bridgeport and Hardinge Mills | 2 | 03-29-2009 06:07 AM |
| Need Help!- servo drives | Minnesota HD 10 | Servo Motors and Drives | 0 | 03-25-2009 11:52 AM |
| servo drives help | bbrreid | Machine Problems, Solutions , Wireless DNC, serial port | 0 | 11-09-2007 02:55 PM |
| Servo drives | quickerz | Servo Motors and Drives | 1 | 01-21-2005 10:24 AM |
| New servo drives? | CNCadmin | Servo Motors and Drives | 1 | 12-25-2004 08:47 AM |
