| Product Announcements & Manufacturer News If you are a manufacturer or company with relevant news related to machining or have a new product announcement you may post it here only! (Commercial Posting Forum) |
| 80/20 Tips The align-a-grooves in 80/20's extrusion identify the bar as being fractional, but they serve a much more important role. During project assembly, the alignment of these grooves ensures that joints and corners are square and properly aligned. 80/20 Inc. www.8020.net |
| 80/20 Tips - Preloading Fasteners Before assembly of your project, be sure to preload any joining plates, brackets, or fasteners. This will allow for much easier assembly as you will be able to focus on the assembly itself, not searching for individual t-nuts or screws. 80/20 Inc. www.8020.net |
| 80/20 Tips - Linear Bearings If you find that your linear bearings are not easily sliding across the extrusion, try hitting each side of the bearing with a soft faced mallet. This will align the bearing pads with the slot, allowing for ease of motion. 80/20 Inc. www.8020.net |
| 80/20 Tips- Panel Gasket Before installing panel gasket, spray a rag with Armor All and wipe down the gasket. This will do two things. One, it will allow the gasket to slide easily into the t-slot. Two, it will help protect the gasket from cracking, fading, or discoloration. 80/20 Inc. www.8020.net |
| 80/20 Tips - Drop In T-Nuts If you come across a situation where you need to add a t-nut to a bar that is captivated on both ends, drop in t-nuts are your answer. They allow you to load from the profile side, as opposed to the end of the profile. This prevents wasted time tearing down and rebuilding your project. 80/20 Inc. www.8020.net |
| 80/20 Tips - HT Series Profiles Looking for a cost effective solution? Take a look at 80/20's HT Series profiles. These profiles are structured around 1.5" square tubes with centered, pre-drilled holes at 1.5" intervals. Lighter than tslotted profiles and put together with simple hand tools, HT provides significant savings. Take a quick look at these profiles at www.8020.net/HT-Series-.asp. 80/20 Inc. www.8020.net |
| 80/20 Tips - Quick Frame Need a framing system for light duty applications? Quick Frame could be your answer. Quick Frame is a tubular framing system that is assembled by hammering tough nylon corners into the tube ends, creating a connection. Great for light duty guards, shelving, cabinets, enclosures, or displays. For more information regarding Quick Frame, visit http://www.8020.net/Quick-Frame-1.asp. 80/20 Inc. www.8020.net |
| 80/20 Tips - "L" Wrench and Cheater Pipe If you are having trouble getting the maximum torque on fasteners, try using a cheater pipe. This with a "L" hex wrench will allow you to get more leverage than "T" wrenches or hex drivers. 80/20 Inc. www.8020.net |
| 80/20 Tips - Custom Machining 80/20 offers custom machining to any of your tslotted parts and pieces. This cost effective service will allow you to complete your project with free design assistance! For more information regarding custom machining, go to www.8020.net/Service-3.asp. 80/20 Inc. www.8020.net |
#10
| Big News: Smooth Fractional Profiles Now Available! 80/20 is now offering smooth fractional profiles! Same 15 series profiles with the clean feel and look of a smooth surface. 4 New profiles have been added to the lineup: -1.5" x 1.5" light smooth -1.5" x 1.5" ultra light smooth -1.5" x 3.0" light smooth -3.0" x 3.0" light smooth For more information regarding these new offerings, please go to www.8020.net/new_products.asp. 80/20 Inc. www.8020.net |
#11
| 80/20 Tips: Wiring Duct, Clips, Clamps, Blocks and Ties Need some help organizing the wiring or cables around your machine? Try wiring duct, clips, clamps, blocks and ties. These accessories mount directly on the t-slot and keep cables, wires, tubes out of your way and organized. For more information, go to www.8020.net. 80/20 Inc. www.8020.net |
#12
| Are these extrusions 6061? |
| Tags |
| aluminum extrusion, aluminum framing |
| Tips on Roughing , Please. | lostkoss | General Metalwork Discussion | 19 | 10-09-2008 05:36 PM |
| Tips for JGRO | Netjams | JGRO Router Table Design | 1 | 01-06-2007 06:06 AM |
| anybody compare HT finecut tips to TD 1Torch tips for dross? | Knut | CNC Plasma and Waterjet Machines | 0 | 09-29-2006 02:17 PM |
| Eng-tips forum | DEW | Mechanical Calculations/Engineering Design | 2 | 08-18-2006 12:43 PM |
| Drafts: Tips for vendors and tips for RFQ writers... | InspirationTool | Employment Opportunity | 3 | 12-20-2005 09:44 PM |
